macos packaging using homebrew
This subforum is specifically to discuss packaging issues on different platforms (windows, mac, linux), and using different packaging systems (conda, etc...)
ipatch
Re: macos packaging using homebrew
Post by ipatch »
i tried the `brew postinstall openssl` unfortunately that doesn't seem to resolve my issues.
i've created an apple `FreeCAD.app` bundle that you can experiment with locally if you'd like see what it is i'm talking about.
https://github.com/ipatch/homebrew-free ... 20.freecad
chennes
Post by chennes »
Can you try https://github.com/FreeCAD/FreeCAD/pull/5131 ? -- I rewrote large swaths of the addon manager, and I'm hoping it gives a more verbose error message.
Chris Hennes
Pioneer Library System
ipatch
Post by ipatch »
chennes wrote: Mon Nov 08, 2021 10:49 pm Can you try https://github.com/FreeCAD/FreeCAD/pull/5131 ? -- I rewrote large swaths of the addon manager, and I'm hoping it gives a more verbose error message.
sure, just give me a few. (a day or two).
there are a lot of hard coded paths related to the mac app bundling specifically, `/usr/local` which will fail outright in macos homebrew is installed in a directory other than `/usr/local`.
Gift
Post by Gift »
ipatch wrote: Mon Nov 08, 2021 9:33 pm i tried the `brew postinstall openssl` unfortunately that doesn't seem to resolve my issues.
Ok, I test your Image:
>>> import ssl
>>> print(ssl.get_default_verify_paths())
DefaultVerifyPaths(cafile=None, capath=None, openssl_cafile_env='SSL_CERT_FILE', openssl_cafile='/Users/microbrewer/homebrew/etc/openssl@1.1/cert.pem', openssl_capath_env='SSL_CERT_DIR', openssl_capath='/Users/microbrewer/homebrew/etc/openssl@1.1/certs')
With conda version:
>>> import ssl
DefaultVerifyPaths(cafile='/Applications/FreeCAD_x86.app/Contents/Resources/ssl/cacert.pem', capath=None, openssl_cafile_env='SSL_CERT_FILE', openssl_cafile='/Users/runner/work/FreeCAD-Bundle/FreeCAD-Bundle/conda/osx/APP/FreeCAD.app/Contents/Resources/ssl/cert.pem', openssl_capath_env='SSL_CERT_DIR', openssl_capath='/Users/runner/work/FreeCAD-Bundle/FreeCAD-Bundle/conda/osx/APP/FreeCAD.app/Contents/Resources/ssl/certs')
We need to included it in the app with homebrew similar conda.
edit:
export SSL_CERT_FILE=${PREFIX}/ssl/cacert.pem # https://forum.freecadweb.org/viewtopic.php?f=3&t=42825
ipatch
Post by ipatch »
Gift wrote: Tue Nov 09, 2021 6:00 pm
>>> import ssl
With conda version:
>>> import ssl
edit:
wow that's freaking awesome, thank you so much for looking into this. hopefully i can apply fix later today.
Gift
Post by Gift »
ipatch wrote: Tue Nov 09, 2021 8:03 pm ...
Please see this commit for my first steps to solved it.
