Discussion: State of the snap (Snap Packaging)
kkremitzki
Re: Discussion: State of the snap (Snap Packaging)
Post by kkremitzki »
Isn't it LGPL2+ (or later, i.e. it can also be distributed under LGPL2.1 or LGPL3)?
vocx
Post by vocx »
kkremitzki wrote: Wed Jul 29, 2020 2:30 pm Isn't it LGPL2+ (or later, i.e. it can also be distributed under LGPL2.1 or LGPL3)?
I think it can be distributed as LGPL3 (any future version, in fact), yes, but it seems to me a bit misleading in this case. If we want to talk about the project itself, it is LGPL2.
ppd
Post by ppd »
vocx wrote: Wed Jul 29, 2020 5:20 am I checked the Snapcraft store and it seems that FreeCAD is listed as LGPL3. It should be LGPL2. The difference is important.
I'm not involved with the upstream snap, so that's a task for vejmarie.
Try FreeCAD from the Snap Store: Stable releases (in latest/stable) & daily builds (in latest/edge). Supports installing additional python packages via pip!
vejmarie
Re: Addon manager not working in v0.19 beta snap
Post by vejmarie »
JulianStirling wrote: Thu Jul 23, 2020 8:17 am I have installed the beta of v0.19 as I wanted to play with Assembly 4. I am on Kubuntu 20.04 so I can't the freecad-daily PPA. So I have installed with snap.
When I open the add-on manager I can see all the packages, but if I click to "Install selected" the program hangs at "Cloning module". There is no output in the terminal.
A clue as to what it might be is if I go to the macro tab in the addon manager it tells me:
"Something went wrong with the Git Macro Retrieval, possibly the Git executable is not in the path"
Git is definitely on the PATH, I use it every day from the terminal. Perhaps this is a snap sandboxing issue? I don't really understand snap, I have tried to avoid the things in the past, but it is becoming more difficult.
OS: Ubuntu Core 16 (KDE/plasma)
Version: 0.19.21777 (Git)
Build type: Unknown
Hash: 478823b90967a9b76796c64f74b8e3a5440150fa
Python version: 3.5.2
Qt version: 5.5.1
Mod Edit: merged this thread from another.
Can you check in your home directory if you have a .snap directory ? If yes what are the write permissions ? I can install Assembly4 with the snap (I am using it with my build for CADCloud).
vejmarie
Post by vejmarie »
Build type: Unknown
Qt version: 5.5.1
vejmarie
Post by vejmarie »
Just updated it.
vejmarie
Post by vejmarie »
Build type: Unknown
Qt version: 5.5.1
JulianStirling
Post by JulianStirling »
The .snap dir is owned by my user account with 700 permissions, the only file inside is warnings.json. The snap also cannot open files from an external drive. I have given up with it, as Ubuntu pushes onto snap more and more I am simply looking for an exit from Ubuntu.
sgrogan
Post by sgrogan »
JulianStirling wrote: Thu Aug 20, 2020 7:19 pm as Ubuntu pushes onto snap more and more I am simply looking for an exit from Ubuntu.
20.04 is working on the daily PPA now.
"fight the good fight"
JulianStirling
Fantastic! Thanks!
