To me it looks good for now, hence if you will go ahead an make a PR, adding snapcraft.yaml, that likely shouldn't represent any big problems. The decisions, regarding enabling the stable/per-commit builds on Snapcraft, from the FreeCAD GitHub repo, that can be made after. If it really comes down to pressing on a few buttons, like mentioned in the above blog post, i don't see any special reason, on why not giving it a try.ppd wrote: ↑Thu May 28, 2020 10:17 am An alternative, based on the PPA and without compiling all those external dependencies: https://github.com/ppd/FreeCAD/tree/snap-ppa/snap
Discussion: State of the snap (Snap Packaging)
Re: Discussion: State of the snap (Snap Packaging)
Reusing all that great Debian/Ubuntu packaging from the PPA + more recent Qt from KDE Neon seems the way to go. Let's KISS and only build the bare minimum.
I will go over all remaining optional dependencies and make sure nothing's missing. I will temporarily publish the snap as "freecad-ppd" in the Snap Store for anyone who wants to try it out.
Of course, I'm still eager to hear from vejmarie. After all, he's the maintainer
Building on build.snapcraft.io is dead simple. We did it for QElectrotech (https://snapcraft.io/qelectrotech): it builds on every commit to master. Another option is via Travis or some other CI tool.
For testing purposes, the PPA-based build: https://snapcraft.io/freecad-ppd
Install from the store or from the terminal:
snap install --edge freecad-ppd
It seems to work.ppd wrote: ↑Sun May 31, 2020 7:34 pm For testing purposes, the PPA-based build: https://snapcraft.io/freecad-ppd
OS: Ubuntu Core 18 (ubuntu:GNOME/ubuntu)
Version: 0.19.21194 +118 (Git)
Branch: snap-ppa
Hash: 1f618c5cf8e0c0e8fffc073a678dd14207f6e908
Python version: 3.6.9
Qt version: 5.12.3
Also, why does it say 21194 +118, instead of 21312? That's a bit odd. Currently the master branch is in commit 21349.
The reported hash of the snap doesn't seem to exist in the Git repository.
git log 1f618c5cf8
OS: Ubuntu 18.04.4 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19.
Branch: unknown
Hash: 2330eef823b32ac412d839031cc174353a76b013
Qt version: 5.9.5
git log 2330eef82 --oneline
git rev-list 2330eef823 --count
We can add some auto scaling via QT_SCALE_FACTOR (scales fixed size fonts) or QT_AUTO_SCREEN_SCALE_FACTOR (does not).
You can play around with setting QT_AUTO_SCREEN_SCALE_FACTOR=1 and running freecad-ppd.freecad and report whether you like it better. Or try QT_SCALE_FACTOR=2 freecad-pdd.freecad or similar.
The snap is based on code in the snap-ppa branch. Naturally, this means that those commits are not in the master branch and thus the hash differs.
QT_AUTO_SCREEN_SCALE_FACTOR doesn't seem to work with me.
This gives me about the same size as I have with the native version that I normally use.
QT_SCALE_FACTOR=1.2 freecad-pdd.freecad
One key-difference is the platformtheme in use. The snap has access to:
/snap/kde-frameworks-5-core18/32/usr/lib/x86_64-linux-gnu/qt5/plugins/platformthemes$ ls
KDEPlasmaPlatformTheme.so libqxdgdesktopportal.so
The snap has been updated with the following features:
- Use of xdg-desktop-portal file dialogs
- Private font cache to prevent incompatibilities between host & snap fontconfig
gmsh is now meshing inside the snap and thus the FEM workbench is one step closer to working correctly.
Great work, sir
Thank you for your efforts
