Chocolatey - Windows Package Manager that FreeCAD can be installed from
Re: Chocolatey - Windows Package Manager that FreeCAD can be installed from
FreeCAD 0.19.x now packaged and distributed through Chocolatey
Original ticket: https://github.com/chocolatey-community ... ssues/1146
PR: https://github.com/chocolatey-community ... /pull/1277
Chocolatey 0.19.x page: https://chocolatey.org/packages/freecad ... .20052-dev
redbaron2
Post by redbaron2 »
The Latest build of the FreeCAD 0.19 dev stream failed to build a windows
Win-Conda_vc14.x-x86_64.7z
version?
This failure will make and has made the current chocolatey package FreeCAD 0.19.0.20052-dev not installable.
I'm curious to find out if this was a error or a build fault?
Thanks for any help with this issue.
kunda1, sgrogan do either of you know what might have happen?
redbaron2 wrote: Fri Jun 19, 2020 8:17 pm kunda1, sgrogan do either of you know what might have happen?
No idea. Anybody able to chime in?
sgrogan
Post by sgrogan »
Travis timed out 7ziping the package.
Should be fixed?
https://travis-ci.org/github/FreeCAD/Fr ... /700214140
https://github.com/FreeCAD/FreeCAD/rele ... g/0.19_pre
"fight the good fight"
redbaron2
Post by redbaron2 »
Thank You.
I was hoping it was something like a timing issue.
redbaron2 wrote: :bell:
@redbaron2 any idea what the issue here is ?
sgrogan wrote: pinged by pinger macro
@sgrogan we should add mention of chocolatey to the 0.19 release page.
Something to the effect of:
For windows users there the option of using [Chocolatey](https://chocolatey.org/) to manage and track upstream 0.19 releases. The 0.19 package is available of it's own [dedicated FreeCAD Chocolatey package page](https://chocolatey.org/packages/freecad)
sgrogan
Post by sgrogan »
Kunda1 wrote: Thu Oct 29, 2020 10:35 pm Something to the effect of:
done
sgrogan wrote: Thu Oct 29, 2020 10:55 pmdone
Thx! :D
redbaron2
Post by redbaron2 »
@Kunda1
I will check to see what is the problem with the verification, but since it is a pre development build. I would not really worry about it.
The Chocolatey verification system doesn't always test pre development builds.
