Good day everyone.
I am learning to develop stuff on freeCAD and am first trying to compile it myself following the tutorial linked here: https://wiki.freecadweb.org/Compile_on_Windows
On the step for Running and installing FreeCAD there are 2 methods to build and run the program. I tried both steps, and when I clicked on the exe file for FreeCAD an error popped up saying I needed python39.dll for both those methods: https://freeimage.host/i/H9MWwzu
Currently on the tutorial, it says python38.dll is used and in the LibPack I downloaded from here python38 is what was available.
Am I missing something? Was I supposed to use python 3.9 from the beginning?
Thank you very much in advance.
[Solved] Trouble compiling FreeCAD and problems with python version
Re: Trouble compiling FreeCAD and problems with python version
I just compiled and had no problems.
I followed the instructions exactly, and I made no changes to anything. The only oddity is that the Help-About does not pick up the version number. Probably something missing in the cmake files. The actual version is 0.21.31036.
Version: 0.21.Unknown
* FeedsAndSpeeds 0.4.0
* FeedsAndSpeeds-master.zip
* freecad.gears 1.0.0
* Help 1.0.3
My guess is that one of two things went wrong for you.
* You did not follow the instructions exactly, or you made some changes to the files.
* You have a Windows Path environmental variable set that tries to call some other (non-FreeCAD) Python installation.
Gene
Hello Good Day.
After reading your reply and checking any pythons installed, it seems it has been detecting another python installation that isn't on paths. After taking care of that, it has been compiling and executing as expected.
Thank you very much
Thank you very much
