glider workbench is added by looo who is the packager for the appimage, IIRC he develops that workbench too. The help addon thing is a bug with the addon manager I think, can you weight in @chennes ?
Those backups get created when something goes wrong with a git update that requires a re-clone. As a general rule they can be safely deleted if the addon is not creating any trouble, but I have not yet automated that process.
@looo can you give a look to this thread pls?
the fact that Glider is delivered with AppImage, is it an error or something planned?
@chennes I am not behind my personnal computer, I'll do that this evening. I will remove and put it back this Addon. Would also be great to have the possibility to translate the interface on Crowdin of Help Addon. I keep you in touch.
chennes wrote: ↑Mon Oct 10, 2022 12:59 am
as you can see in my previous post, after removing the Help Addon, I still have the backup trace.
when you say, one can remove it, how do you manually do that?
david69 wrote: ↑Mon Oct 10, 2022 10:01 am
the glider workbench is shipped with the weekly builds, I can remove it if wanted.
I also wish the removal of Reverse engineering, Robot workbenches as they are no more supported as official workbench with V1.0.
Paddle has also raised the point about the shortcut <none> and I don't know the status about Test Framework and Web.
I guess it requires extra work to purge these workbenches. That's an other story.
