Addon Manager freezes FreeCAD up
chennes
Re: Addon Manager freezes FreeCAD up
Post by chennes »
Olav wrote: Tue Oct 04, 2022 12:09 pm Seems fine, no?
Yep - can you now try to add to the end of that sequence:
vendor_path = os.path.join(FreeCAD.getUserAppDataDir(), "AdditionalPythonPackages")
call_args = [python_exe, "-m", "pip", "--disable-pip-version-check", "list", "-o", "--path", vendor_path]
proc = subprocess.run(
                call_args,
                stdout=subprocess.PIPE,
                stderr=subprocess.PIPE,
                check=True,
                timeout=30,
print(proc.stdout.decode())
Chris Hennes
Pioneer Library System
Olav
Post by Olav »
chennes wrote: Tue Oct 04, 2022 12:40 pm Yep - can you now try to add to the end of that sequence:
...                 call_args,
...                 stdout=subprocess.PIPE,
...                 stderr=subprocess.PIPE,
...                 check=True,
...                 timeout=30,
So, nothing is printed after that last line. I'm guessing that I should have a directory AdditionalPythonPackages somewhere? I tried creating it manually in ~/.local/share/FreeCAD but that doesn't seem to do anything either.
chennes
Post by chennes »
Actually, nothing is a perfectly reasonable response: it just means the Addon Manager hasn’t had to install any dependencies. The important thing is it didn’t hang or give an error.
Chris Hennes
chennes
Post by chennes »
OK, I've made a number of changes that are now merged into the main branch of development, so a git pull should grab them for you. This should at least stop it from hanging on startup, so we can focus on why it's not just gracefully delivering an empty result set. For reference, it's git commit 0963860dd.
Chris Hennes
Olav
Post by Olav »
chennes wrote: Tue Oct 04, 2022 2:00 pm OK, I've made a number of changes that are now merged into the main branch of development, so a git pull should grab them for you.
Thank you! I just did the pull & make cycle again and... now I can actually use the Addon Manager to install addons! No freezes or scary messages anymore. Case closed, as far as I'm concerned. For curiosity: do you think my method of installing from source had anything to do with this?
Also if I still need to test anything, just let me know.
OS: Ubuntu 22.04.1 LTS (XFCE/xubuntu)
Version: 0.21.30531 (Git)
Build type: Unknown
Hash: 0963860dd656f25c8faf73ecafec1e8ff0724db2
Python 3.10.6, Qt 5.15.3, Coin 4.0.0, Vtk 7.1.1, OCC 7.5.2
  * Curves 0.5.10
  * A2plus 0.4.59d
  * Assembly3 0.11.3
  * fasteners 0.4.15
chennes
Post by chennes »
Installing from source should be totally fine (after all, it's how I use FreeCAD!). I understand why, given no response from pip, the Addon Manager would have locked up, but I don't understand why pip isn't generating output yet.
Chris Hennes
Olav
Post by Olav »
chennes wrote: Tue Oct 04, 2022 5:16 pm but I don't understand why pip isn't generating output yet.
To be honest I'm not even sure what "pip" is so I can't help you figure it out (I just know that it has something to do with Python). But as I said if I can test something for you I would be glad to do it. I do read the forums a few times a week even if I don't participate much.
