Hi All,
We use msvc to compile FreeCAD (git commit 8b4e114b9d), and it is failed testBooleanCommonCase (PartDesignTests.TestBoolean.TestBoolean) ... Recompute failed! Please check report view. Could anyone help to look at this issue? Thanks.
Repro steps:
1. open VS2019 x64 tools command
2. git clone https://github.com/FreeCAD/FreeCAD.git F:\gitP\FreeCAD\FreeCAD
3. download https://github.com/apeltauer/FreeCAD/re ... ack_12.5.2 F:\gitP\FreeCAD\tools\FreeCADLibs_12.5.2_x64_VC17
4. mkdir F:\gitP\FreeCAD\FreeCAD\build_amd64 && cd F:\gitP\FreeCAD\FreeCAD\build_amd64
5. set _CL_= /permissive- or set _CL_= /std:c++latest
6. set PATH=F:\gitP\FreeCAD\tools\FreeCADLibs_12.5.2_x64_VC17\bin;%PATH%
7. set PATH=F:\gitP\FreeCAD\tools\FreeCADLibs_12.5.2_x64_VC17\bin\Scripts;%PATH%
8. cmake -G "Visual Studio 16 2019" -A x64 -DCMAKE_SYSTEM_VERSION=10.0.18362.0 -DFREECAD_LIBPACK_DIR=F:\gitP\FreeCAD\tools\FreeCADLibs_12.5.2_x64_VC17 -DBUILD_FEM_NETGEN=OFF -DFREECAD_RELEASE_PDB=OFF -DFREECAD_RELEASE_SEH=OFF -DCMAKE_BUILD_TYPE=Release.
9. msbuild /m /p:Platform=x64 /p:Configuration=Release FreeCAD.sln /t:Rebuild
10.cd F:\gitP\FreeCAD\FreeCAD\build_amd64\bin
11.xcopy F:\gitP\FreeCAD\tools\FreeCADLibs_12.5.2_x64_VC17\bin F:\gitP\FreeCAD\FreeCAD\build_amd64\bin /k/r/e/i/s/c/h/f/y
12.FreeCADCmd.exe --run-test 0 2>&1
More info:
OS Version: windows server 2019
VS version: VS2019 (16.11.18)
msvc version: 19.31.31009.95 (msvc inner latest build)
FreeCAD failed to build in runtest on MSVC
Reason: added git commit hyperlink
- adrianinsaval
Re: FreeCAD failed to build in runtest on MSVC
your link to the libpack is broken but I think the current libpack is hosted here: https://github.com/FreeCAD/FreeCAD-LibPack/releases not there. I don't know if that could be the cause. Also, why compile a two weeks old version? If you have issues the first thing to try is to see if the latest still has the same issue.
Libpack 12.5.2 is at least 18 months old. I doubt it will work well for builds using the current master.
Gene
Gene
We used the latest LibPack-0.20 Version 2.6, but this error still exists.
- test.log.3 (1).log
- detail info
- (439.27 KiB) Downloaded 21 times
- adrianinsaval
The text "Recompute failed! Please check report view." does not imply that the test failed, sometimes the recompute failure is exactly the expected outcome of the test, as you can see these test are reported as passing (ok):
you need to look at the test listed as failing or having errors after the
your log says
That's the one that's failing
ok
testBooleanCutCase (PartDesignTests.TestBoolean.TestBoolean) ... Recompute failed! Please check report view.
ok
FAIL: testPlacement (TestPartApp.PartTestShapeRotate)
Yes, thanks, you are right. This failure is really due to FAIL: testPlacement (TestPartApp.PartTestShapeRotate). Could you help look?
According to issue #7486 the failure is in line 230, i.e.
Here is the extracted test:
So, what's the output of
and
self.assertTrue(box.Placement.isSame(p2 * p1))
import math
from FreeCAD import Base
box = Part.makeBox(1, 1, 1)
box.Placement.Base = Base.Vector(10, 10, 10)
box.rotate((0, 0, 0), (0, 0, 1), 90)
p1 = Base.Placement()
p1.Base = Base.Vector(10, 10, 10)
p2 = Base.Placement()
p2.Rotation.Angle = math.radians(90)
# This gives False for you
box.Placement
p2 * p1
