19.4.0 / 0.20.1 stops during start-up
dirkdirk
Post by dirkdirk »
Hello
Newbie here.
My PC is slow, 1.3GHz, 4GB, 100GB SSD, Win 10 64-bits
First I tried 0.20.1, then 0.19.4.
Start-up with loading window stops after some seconds.
Attached are the computer configuration and some standard logs:
My Computer
FreeCad --dump-config
FreeCad -u user.cfg
First unnormal log entry is
Log: Id: 3168: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFEF105BAFF)
Many similar following.
Thanks for ideas and hints.
Best regards
DirkDirk
logs_startup.txt
(85.49 KiB) Downloaded 32 times
Re: 19.4.0 / 0.20.1 stops during start-up
Moved to install/compile subforum
DOX
Post by DOX »
Hi, dirkdirk. were you able to solve the startup issue you had with FreeCAD? and how did you go about it. I am new to the App myself, and I'm experiencing the same issue. Seriously hoping someone could point me in the right direction. Thanks
Have a look at the Known OS specific issues.
