i downloaded FC 29923-2022-08-03 win-conda but when unzipped the exe doesn't run... i don't get any error but the application looks like pending in the process.
the previuos version 29485-2022-07-28 runs perfectly
FC 29923-2022-08-03 win-conda doesn't run (Win7)
- jimmihenry
Re: FC 29923-2022-08-03 win-conda doesn't run (Win7)
Hello Piero69,
yes it was also a shock for me. It did require the api-ms-win-core-path-l1-1-0.dll in my case. I have downloaded the dll copied it into the FreeCAD's bin folder and it failed. (https://forum.freecadweb.org/viewtopic. ... 26#p615026)
You may solve the problem with a modified 64bit api-ms-win-core-path-l1-1-0.dll. Here is the download link: https://github.com/nalexandru/api-ms-wi ... K/releases
Just place the 64bit "api-ms-win-core-path-l1-1-0.dll" in FreeCAD's bin folder, and you should be good, hopefully. Please try it out maybe this is the issue.
Cheers.
Cheers.
- In here geoes the dll.PNG (30.63 KiB) Viewed 748 times
thanks so much... it's run now
jimmihenry wrote: ↑Thu Aug 04, 2022 1:04 pm Hello Piero69,
Cheers.
- jimmihenry
Hey Piro69, you are welcome!
You may won't to place, copy the DLL's in your windows system. Blender 2.93 would also benefit from it .
Win 7 user until the hardware fails !
- jimmihenry
SOLVED!
The modified DLL's release 0.3.1
To make FreeCAD py310 work with Windows 7 you have to copy the files as followed:
64 bit api-ms-win-core-path-l1-1-0.dll to C:\Windows\System32
32 bit api-ms-win-core-path-l1-1-0.dll to C:\Windows\SysWOW64
or
64 bit api-ms-win-core-path-l1-1-0.dll to ...\FreeCAD\bin
