Where is 0.19 executable for Linux 64 ?
Hello. I am trying to find out an executable binary of 0.19 version, for Ubuntu. I just want download it - double click and run. Last year I installed one 0.19 version in my other computer very easily. But now there is a labyrinth at the installation pages with no avail.
Please help.
Please help.
- adrianinsaval
Re: Where is 0.19 executable for Linux 64 ?
what do you mean labyrinth? It's pretty straightforward at the download page to get an appimage for 0.20, the current stable version (which I recommend rather than 0.19). If you really want them older releases can be found at the github releases page: https://github.com/FreeCAD/FreeCAD/releases just scroll down to the version you want, the latest in 0.19 series with an appimage available is 0.19.3: https://github.com/FreeCAD/FreeCAD/releases/tag/0.19.3
I prefer not to discuss it now. Thanks anyway.
From what I know download page is not complicated.
A part that Linux 64 is not telling nothing as Linux has a different eay to specify Architectures of the CPU used.
Mist near is Linux x86_64 as there are different architecture fir 64bitb cpus even Arm64 to cite one.
The Download is in FC main page and there is a link somewhere to reach GitHub repos.
GitHub repo are two, one for stable and for weekly builds.
Once saved GH links are pretty straightforward to use, a part from different versions supplied for different OS.
I've installed an AppImage last week to substitute my conda install for 0.20 with the 0.21 dev when it was available.
Plus I've installed a 0.19.3 on a second computer.
as deb files are usually outdated and PPA for Ubuntu is somewhat discouraged by developers, recently some advice was added on download page an the "usual advice" done here in the Forum is to use an AppImage.
EDIT:
I have checked with my browser:
For each supported version in:
https://www.freecadweb.org/downloads.php
There is a direct link to download a version for each OS and a clear link to the wiki page, as example for Linux:
https://wiki.freecad.org/Installing_on_Linux
In effect there are Link broken and the index is outdated.
Let's signal it.
I made this post:
https://forum.freecadweb.org/viewtopic. ... 16#p612416
Hope it helps
But it not seem a labirinth, it only a matter of multiple choices, and for Linux this is the "usual way", at least for users that have frequented Linux for some time, and appreciate the "many different ways" of doing things.
END EDIT:
Other cases are slightly more complicated and error prone.
EDIT:
Let's signal it.
I made this post:
Hope it helps
END EDIT:
- adrianinsaval
we simply do not provide standalone deb packages, this has been the case for several versions, I believe 0.19 included, you may try the ppa but it is currently unmaintained so it is not the best idea. There are some issues with some appimage versions in some distros so I understand if this frustrates you, it should be possible to run with something like this:
LD_PRELOAD=/usr/lib/x86_64-linux-gnu/libstdc++.so.6 ./FreeCAD_0.19.3-Linux-Conda_glibc2.12-x86_64.appimage
AppImages are not different for Ubuntu.
If you go to the stable release GitHub page (there is a link around here from @adrianinsaval ) and scroll down you will find it there is 0.19.4 that was not released for Linux and Mac as clearly told in the page but 0.19.3 is present.
Here the direct link.
https://github.com/FreeCAD/FreeCAD/rele ... 4.AppImage
Hope it helps.
Carlo D
Hope it helps.
Carlo D
After 8 post we finally find the direct link.onekk wrote: ↑Mon Jul 25, 2022 7:26 am
Carlo D
OK I agree, it is not a labyrinth, it is a highway.
Thanks all
