FreeCad 0.20 on windows only runs as administrator
TWrecks
Post by TWrecks »
I installed the FreeCAD stable release from the main download page. It launched fine the first time from the installer, but subsequent attempts get an "Unknown Error" dialog. If I "run as administrator" then it launches fine.
I originally "installed for all" but tried uninstalling and re-installing just for me, but had the same issue.
Thanks for any help-
Tim
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
  * 3D_Printing_Tools
  * CADExchanger
  * CurvedShapes
  * Curves
  * fcgear
  * Manipulator
  * nurbs
  * Render
Re: FreeCad 0.20 on windows only runs as administrator
perhaps your config was written as admin and now can only be accessed as admin, go to %APPDATA% in the file explorer and delete or rename the FreeCAD folder there then try again
TWrecks
Post by TWrecks »
adrianinsaval wrote: Tue Jun 21, 2022 1:30 am perhaps your config was written as admin and now can only be accessed as admin, go to %APPDATA% in the file explorer and delete or rename the FreeCAD folder there then try again
I should have mentioned I also have used FreeCAD for some time (since v0.15), and currently also have 0.19 installed. 0.19 still launches fine w/o administrator privileges. The files in %APPDATA%\Roaming\FreeCAD are mostly old, but I have "full control" access to them.
I tried renaming it, v0.20 created a new FreeCAD folder w/ nothing inside and still errored out.
Tim
very strange, can you check the log?
TWrecks
Post by TWrecks »
I'm not sure what logs you are referring to? I don't see anything in the windows event viewer, and I don't see any freeCAD .log files.
Tim
TWrecks wrote: Tue Jun 21, 2022 3:18 pm I'm not sure what logs you are referring to? I don't see anything in the windows event viewer, and I don't see any freeCAD .log files.
You can start FreeCAD from the console and check the output there. And you can start it (from there) with the additional parameter --write-log which will write a log file to %APPDATA%\Roaming\FreeCAD.
TWrecks
Post by TWrecks »
It appears to die before even creating a log file. If I run the command shell as administrator, then it makes a log file.
Tim
perhaps some antivrus is interfering? is the splashscreen shown?
Kartoffelpüre
Post by Kartoffelpüre »
If you are logged in as Admin and Install
winget install FreeCAD.FreeCAD
from Terminal Freecad got installed into C:\Users\%username%\AppData\Local\ of the currently logged in administrator instead it gets installed, so all user could use Freecad.
In my opinion Freecad should only install into C:\Users\%username%\AppData\Local\ if the user do not have Admin rights.
