Here is my version info (built from source Master, pulled this morning at 10 CDT):
Version: 0.20.29190 (Git)
Build type: Debug
Hash: 81be38ea8dcec49376b6ab8e08f4a85605639f8d
* FC_TabbedBoxWorkbench
I have had a problem for a while now where I can't launch the part design workbench. It throws the following error:
11:58:48 DLL load failed while importing PartDesignGui: The specified module could not be found.
11:58:48 Traceback (most recent call last):
File "<string>", line 53, in Initialize
File "E:\Dev\FreeCAD19_Output\bin\Lib\site-packages\shiboken2\files.dir\shibokensupport\__feature__.py", line 142, in _import
Log: Using E:\Dev\FreeCAD19_Output\Mod as module path!
Err: Error in InitApplications [WinError 3] The system cannot find the path specified: 'E:\\Dev\\FreeCAD19_Source\\FreeCADLibs_12.5.5_x64_VC17\\FreeCADLibs_12.5.5_x64_VC17\\bin'
Thanks in advance,
Frank Alviani
[edit] The offending LibPack reference is in the system PATH variable. Is it safe to just edit that to remove the obsolete libpack reference? [/edit]
