during building by clang and clang++ compilers,
this error message shows up
[16/3398] Copying C:/msys64/home/Baba/FreeCAD/src/Mod/AddonManager/compact_view.py to C:/msys64/home/Baba/Build/Mod/AddonManager/compact_view.py
[17/3398] Generating version_check
fatal: not a git repository (or any of the parent directories): .git
'bzr' is not recognized as an internal or external command,
operable program or batch file.
'/home/Baba/FreeCAD/src/Build/C:/msys64/home/Baba/FreeCAD' doesn't exist
svn: E155007: '/home/Baba/FreeCAD/src/Build/C:/msys64/home/Baba/FreeCAD' is not a working copy
Unknown version control
C:/msys64/home/Baba/Build/src/Build/Version.h.out written
[18/3398] Generating Version.h
[19/3398] Building CXX object src/3rdParty/libE57Format/CMakeFiles/E57Format.dir/src/CompressedVectorNodeImpl.cpp.obj
[20/3398] Building CXX object src/3rdParty/libE57Format/CMakeFiles/E57Format.dir/src/Common.cpp.obj
so what is 'bzr' ?
and why svn module gives wrong directory as if it was 2 path's combined together by mistake !!??
thank you.
