During building ( --Build) in msys2 with MinGW
a lot of errors shows up and most of it came from the SMESH module in different error types
for a start the building ended with this text
[138/4251] Linking CXX shared library bin\libSMESH.dll
ninja: build stopped: subcommand failed.
like this
C:/msys64/home/Baba/FreeCAD/src/3rdParty/salomesmesh/inc/SMESH_MeshEditor.hxx:106:32: error: function 'SMESH_MeshEditor::ElemFeatures& SMESH_MeshEditor::ElemFeatures::SetID(int)' definition is marked dllimport
106 | SMESH_EXPORT ElemFeatures& SetID (int ID) { myID = ID; return *this; }
C:/msys64/home/Baba/FreeCAD/src/3rdParty/salomesmesh/inc/SMESH_MeshEditor.hxx:85:18: error: function 'SMESH_MeshEditor::ElemFeatures::ElemFeatures(SMDSAbs_ElementType, bool, bool)' definition is marked dllimport
85 | SMESH_EXPORT ElemFeatures( SMDSAbs_ElementType type=SMDSAbs_All, bool isPoly=false, bool isQuad=false )
[136/4251] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/StdMeshers.dir/src/StdMeshers/StdMeshers_Cartesian_3D.cpp.obj
FAILED: src/3rdParty/salomesmesh/CMakeFiles/StdMeshers.dir/src/StdMeshers/StdMeshers_Cartesian_3D.cpp.obj
C:\msys64\mingw64\bin\c++.exe -DCSFDB -DHAVE_CONFIG_H -DHAVE_SNPRINTF -DStdMeshers_EXPORTS -DWIN32 -DWNT -D_OCC64 -D_WINDOWS -IC:/msys64/home/Baba/Build -IC:/msys64/home/Baba/Build/src -IC:/msys64/home/Baba/FreeCAD/src -IC:/msys64/home/Baba/FreeCAD/src/3rdParty/salomesmesh/src/SMDS -IC:/msys64/home/Baba/FreeCAD/src/3rdParty/salomesmesh/src/Driver -IC:/msys64/home/Baba/FreeCAD/src/3rdParty/salomesmesh/src/DriverUNV -IC:/msys64/home/Baba/FreeCAD/src/3rdParty/salomesmesh/src/DriverDAT -IC:/msys64/home/Baba/FreeCAD/src/3rdParty/salomesmesh/src/DriverSTL -IC:/msys64/home/Baba/FreeCAD/src/3rdParty/salomesmesh/src/StdMeshers -IC:/msys64/home/Baba/FreeCAD/src/3rdParty/salomesmesh/inc -IC:/msys64/home/Baba/Build/src/3rdParty/salomesmesh -IC:/msys64/mingw64/include/opencascade -IC:/msys64/mingw64/include/double-conversion -IC:/msys64/mingw64/include/eigen3 -IC:/msys64/mingw64/include/freetype2 -isystem C:/msys64/mingw64/include/vtk-8.2 -Wall -Wextra -Wno-write-strings -Wno-attributes -Wno-sign-compare -Wno-reorder -Wno-switch -Wno-unused-variable -Wno-unused-but-set-variable -Wno-comment -Wno-unused-parameter -Wno-empty-body -Wno-pedantic -Wno-unused-result -Wno-cast-function-type -Wno-maybe-uninitialized -Wno-missing-field-initializers -DSTDMESHERS_EXPORTS -DSMESHUtils_EXPORTS -std=gnu++17 -MD -MT src/3rdParty/salomesmesh/CMakeFiles/StdMeshers.dir/src/StdMeshers/StdMeshers_Cartesian_3D.cpp.obj -MF src\3rdParty\salomesmesh\CMakeFiles\StdMeshers.dir\src\StdMeshers\StdMeshers_Cartesian_3D.cpp.obj.d -o src/3rdParty/salomesmesh/CMakeFiles/StdMeshers.dir/src/StdMeshers/StdMeshers_Cartesian_3D.cpp.obj -c C:/msys64/home/Baba/FreeCAD/src/3rdParty/salomesmesh/src/StdMeshers/StdMeshers_Cartesian_3D.cpp
In file included from C:/msys64/home/Baba/FreeCAD/src/3rdParty/salomesmesh/inc/SMDS_MeshElement.hxx:36,
from C:/msys64/home/Baba/FreeCAD/src/3rdParty/salomesmesh/inc/SMDS_MeshNode.hxx:32,
from C:/msys64/home/Baba/FreeCAD/src/3rdParty/salomesmesh/inc/SMESH_Algo.hxx:33,
from C:/msys64/home/Baba/FreeCAD/src/3rdParty/salomesmesh/inc/StdMeshers_Cartesian_3D.hxx:31,
from C:/msys64/home/Baba/FreeCAD/src/3rdParty/salomesmesh/src/StdMeshers/StdMeshers_Cartesian_3D.cpp:32:
C:/msys64/home/Baba/FreeCAD/src/3rdParty/salomesmesh/inc/SMDS_StdIterator.hxx:37:38: warning: 'template<class _Category, class _Tp, class _Distance, class _Pointer, class _Reference> struct std::iterator' is deprecated [-Wdeprecated-declarations]
37 | class SMDS_StdIterator : public std::iterator< std::input_iterator_tag, VALUE >
In file included from C:/msys64/mingw64/include/c++/12.1.0/bits/stl_algobase.h:65,
from C:/msys64/mingw64/include/c++/12.1.0/memory:63,
from C:/msys64/mingw64/include/boost/smart_ptr/detail/sp_counted_impl.hpp:35,
from C:/msys64/mingw64/include/boost/smart_ptr/detail/shared_count.hpp:27,
from C:/msys64/mingw64/include/boost/smart_ptr/shared_ptr.hpp:17,
from C:/msys64/mingw64/include/boost/shared_ptr.hpp:17,
from C:/msys64/home/Baba/FreeCAD/src/3rdParty/salomesmesh/inc/SMDS_ElemIterator.hxx:33,
from C:/msys64/home/Baba/FreeCAD/src/3rdParty/salomesmesh/inc/SMDS_MeshElement.hxx:34:
C:/msys64/mingw64/include/c++/12.1.0/bits/stl_iterator_base_types.h:127:34: note: declared here
127 | struct _GLIBCXX17_DEPRECATED iterator
In file included from C:/msys64/mingw64/include/vtk-8.2/vtkAtomic.h:28,
from C:/msys64/mingw64/include/vtk-8.2/vtkAtomicTypes.h:18,
from C:/msys64/mingw64/include/vtk-8.2/vtkObjectBase.h:54,
from C:/msys64/mingw64/include/vtk-8.2/vtkObject.h:45,
from C:/msys64/mingw64/include/vtk-8.2/vtkCellArray.h:39,
from C:/msys64/home/Baba/FreeCAD/src/3rdParty/salomesmesh/inc/SMDS_MeshElement.hxx:43:
C:/msys64/mingw64/include/tbb/atomic.h:21:141: note: '#pragma message: TBB Warning: tbb/atomic.h is deprecated. For details, please see Deprecated Features appendix in the TBB reference manual.'
21 | #pragma message("TBB Warning: tbb/atomic.h is deprecated. For details, please see Deprecated Features appendix in the TBB reference manual.")
In file included from C:/msys64/mingw64/include/opencascade/NCollection_IndexedDataMap.hxx:23,
from C:/msys64/mingw64/include/opencascade/Standard_Dump.hxx:17,
from C:/msys64/mingw64/include/opencascade/NCollection_Vec2.hxx:20,
from C:/msys64/mingw64/include/opencascade/NCollection_Vec3.hxx:20,
from C:/msys64/mingw64/include/opencascade/NCollection_Vec4.hxx:18,
from C:/msys64/mingw64/include/opencascade/NCollection_Mat4.hxx:19,
from C:/msys64/mingw64/include/opencascade/gp_Trsf.hxx:21,
from C:/msys64/mingw64/include/opencascade/TopLoc_ItemLocation.hxx:26,
from C:/msys64/mingw64/include/opencascade/TopLoc_Location.lxx:18,
from C:/msys64/mingw64/include/opencascade/TopLoc_Location.hxx:179,
from C:/msys64/mingw64/include/opencascade/TopoDS_Shape.hxx:24,
from C:/msys64/home/Baba/FreeCAD/src/3rdParty/salomesmesh/inc/SMESH_Algo.hxx:39:
C:/msys64/mingw64/include/opencascade/NCollection_StlIterator.hxx:30:15: warning: 'template<class _Category, class _Tp, class _Distance, class _Pointer, class _Reference> struct std::iterator' is deprecated [-Wdeprecated-declarations]
30 | public std::iterator<Category, ItemType, ptrdiff_t,
In file included from C:/msys64/home/Baba/FreeCAD/src/3rdParty/salomesmesh/inc/SMESH_MesherHelper.hxx:32,
from C:/msys64/home/Baba/FreeCAD/src/3rdParty/salomesmesh/src/StdMeshers/StdMeshers_Cartesian_3D.cpp:38:
C:/msys64/home/Baba/FreeCAD/src/3rdParty/salomesmesh/inc/SMESH_MeshEditor.hxx:88:32: error: function 'SMESH_MeshEditor::ElemFeatures& SMESH_MeshEditor::ElemFeatures::Init(SMDSAbs_ElementType, bool, bool)' definition is marked dllimport
88 | SMESH_EXPORT ElemFeatures& Init( SMDSAbs_ElementType type, bool isPoly=false, bool isQuad=false )
C:/msys64/home/Baba/FreeCAD/src/3rdParty/salomesmesh/inc/SMESH_MeshEditor.hxx:93:32: error: function 'SMESH_MeshEditor::ElemFeatures& SMESH_MeshEditor::ElemFeatures::Init(double)' definition is marked dllimport
93 | SMESH_EXPORT ElemFeatures& Init( double diameter )
C:/msys64/home/Baba/FreeCAD/src/3rdParty/salomesmesh/inc/SMESH_MeshEditor.hxx:96:32: error: function 'SMESH_MeshEditor::ElemFeatures& SMESH_MeshEditor::ElemFeatures::Init(std::vector<int>&, bool)' definition is marked dllimport
96 | SMESH_EXPORT ElemFeatures& Init( std::vector<int>& quanities, bool isQuad=false )
C:/msys64/home/Baba/FreeCAD/src/3rdParty/salomesmesh/inc/SMESH_MeshEditor.hxx:100:32: error: function 'SMESH_MeshEditor::ElemFeatures& SMESH_MeshEditor::ElemFeatures::Init(const std::vector<int>&, bool)' definition is marked dllimport
100 | SMESH_EXPORT ElemFeatures& Init( const std::vector<int>& quanities, bool isQuad=false )
C:/msys64/home/Baba/FreeCAD/src/3rdParty/salomesmesh/inc/SMESH_MeshEditor.hxx:104:32: error: function 'SMESH_MeshEditor::ElemFeatures& SMESH_MeshEditor::ElemFeatures::SetPoly(bool)' definition is marked dllimport
104 | SMESH_EXPORT ElemFeatures& SetPoly(bool isPoly) { myIsPoly = isPoly; return *this; }
C:/msys64/home/Baba/FreeCAD/src/3rdParty/salomesmesh/inc/SMESH_MeshEditor.hxx:105:32: error: function 'SMESH_MeshEditor::ElemFeatures& SMESH_MeshEditor::ElemFeatures::SetQuad(bool)' definition is marked dllimport
105 | SMESH_EXPORT ElemFeatures& SetQuad(bool isQuad) { myIsQuad = isQuad; return *this; }
if anyone can help i'll appreciate that
thanks
