Gift
Posts: 769 Joined: Tue Aug 18, 2015 10:08 am
Post
by Gift » Tue Jun 14, 2022 6:27 pm
Yasser wrote: ↑ Tue Jun 14, 2022 5:21 pm
This is the final modification result without using LibPack
hdf5 configuration file exist in this directory so i added it to the path list
and the cmake goes flawless in
cmake ../freecad without errors or warnings
if i succeeded in building freecad i'll post full detail about how it's done for the beginners.
next step
cmake --build ./ is full of trouble
list(APPEND CMAKE_PREFIX_PATH "C:/msys64/mingw64/lib/cmake")
This will be easier:
cmake -DCMAKE_PREFIX_PATH=/mingw64/lib/cmake/ ../FreeCAD
Are you getting the same error message?
C:/msys64/home/.../FreeCAD/FreeCAD/src/3rdParty/salomesmesh/inc/SMESH_MeshEditor.hxx:85:18: error: function 'SMESH_MeshEditor::ElemFeatures::ElemFeatures(SMDSAbs_ElementType, bool, bool)' definition is marked dllimport
edit:
Ok, you started a new topic.
edit2:
Should we (that mean you
) add the hint to wiki for the prefix path?
Gift on Tue Jun 14, 2022 6:44 pm, edited 1 time in total.
Yasser
Posts: 35 Joined: Tue Dec 15, 2020 4:28 pm
Post
by Yasser » Tue Jun 14, 2022 6:44 pm
You mean every time i write this line instead of cmake ../freecad !!
i already wrote the error in one of my previous posts, you can compare it with yours.
this is what i got after updating some lines, it is done free of errors (i hope
$ cmake ../freecad
-- Building for: Ninja
CMake Deprecation Warning at CMakeLists.txt:8 (cmake_policy):
The OLD behavior for policy CMP0072 will be removed from a future version
of CMake.
The cmake-policies(7) manual explains that the OLD behaviors of all
policies are deprecated and that a policy should be set to OLD only under
specific short-term circumstances. Projects should be ported to the NEW
behavior and not rely on setting a policy to OLD.
-- The C compiler identification is GNU 12.1.0
-- The CXX compiler identification is GNU 12.1.0
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: C:/msys64/mingw64/bin/cc.exe - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: C:/msys64/mingw64/bin/c++.exe - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
Yasser =======>
-- CMAKE_MODULE_PATH="C:/msys64/home/Baba/FreeCAD/cMake" ; CMAKE_PREFIX_PATH="C:/msys64/mingw64/lib/cmake"
-- Compiler: GNU, version: 12.1.0
-- Looking for GL/gl.h
-- Looking for GL/gl.h - found
-- Looking for C++ include istream
-- Looking for C++ include istream - found
-- Looking for C++ include ostream
-- Looking for C++ include ostream - found
-- Looking for C++ include fstream
-- Looking for C++ include fstream - found
-- Looking for C++ include sstream
-- Looking for C++ include sstream - found
-- Looking for C++ include ios
-- Looking for C++ include ios - found
-- Looking for C++ include iostream
-- Looking for C++ include iostream - found
-- Looking for C++ include iomanip
-- Looking for C++ include iomanip - found
-- Check for STD namespace
-- Check for STD namespace - found
-- prefix: C:/Program Files (x86)/FreeCAD
-- bindir: bin
-- datadir: data
-- docdir: doc
-- includedir: include
-- libdir: lib
-- cmake: 3.23.2
-- Found Doxygen: C:/msys64/mingw64/bin/doxygen.exe (found version "1.9.4") found components: doxygen dot
-- Found Python3: C:/msys64/mingw64/bin/python3.9.exe (found version "3.9.13") found components: Interpreter Development Development.Module Development.Embed
-- Found XercesC: C:/msys64/mingw64/lib/libxerces-c.dll.a (found version "3.2.3")
-- Found ZLIB: C:/msys64/mingw64/lib/libz.dll.a (found version "1.2.12")
-- PyCXX found:
-- Headers: C:/msys64/home/Baba/FreeCAD/src
-- Sources: C:/msys64/home/Baba/FreeCAD/src/CXX
-- Version: 6.2.8
-- Found OCC: C:/msys64/mingw64/include/opencascade (found version "7.6.2")
-- -- Found OCE/OpenCASCADE version: 7.6.2
-- -- OCE/OpenCASCADE include directory: C:/msys64/mingw64/include/opencascade
-- -- OCE/OpenCASCADE shared libraries directory: C:/msys64/mingw64/lib
-- Found OpenGL: opengl32
-- Found OpenGLU: glu32
-- VTK components: vtkCommonCore;vtkCommonDataModel;vtkFiltersVerdict;vtkIOXML;vtkFiltersCore;vtkFiltersGeneral;vtkIOLegacy;vtkFiltersExtraction;vtkFiltersSources;vtkFiltersGeometry;vtkhdf5;vtkRenderingCore;vtkInteractionStyle;vtkRenderingFreeType;vtkRenderingOpenGL2
-- Check for medfile (libmed and libmedc) ...
-- Found MEDFile: C:/msys64/mingw64/include
-- Looking for pthread.h
-- Looking for pthread.h - found
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD - Success
-- Found Threads: TRUE
-- Found Boost: C:/msys64/mingw64/include (found suitable version "1.79.0", minimum required is "1.55") found components: filesystem program_options regex system thread date_time chrono atomic
-- Found SWIG: C:/msys64/mingw64/bin/swig.exe (found version "4.0.2")
-- Found Eigen3: C:/msys64/mingw64/include/eigen3 (found suitable version "3.4.0", minimum required is "2.91.0")
-- Found Freetype: C:/msys64/mingw64/lib/libfreetype.dll.a (found version "2.12.1")
-- Coin3D libraries found
-- Shiboken2Config: Using default python: .cp39-mingw_x86_64
-- Found PythonInterp: C:/msys64/mingw64/bin/python3.9.exe (found suitable version "3.9.13", minimum required is "3")
-- Found PythonLibs: C:/msys64/mingw64/lib/libpython3.9.dll.a (found suitable version "3.9.13", minimum required is "3")
-- SHIBOKEN_PYTHON_INCLUDE_DIRS computed to value: 'C:/msys64/mingw64/include/python3.9'
-- SHIBOKEN_PYTHON_LIBRARIES computed to value: ''
-- libshiboken built for Release
PySide2 Python module found at C:/msys64/mingw64/lib/python3.9/site-packages/PySide2.
-- Found Matplotlib: C:/msys64/mingw64/lib/python3.9/site-packages/matplotlib (found version "3.5.2")
-- Platform is 64-bit, set -D_OCC64
-- Performing Test _flag_found
-- Performing Test _flag_found - Success
-- [E57] Revison ID: E57Format-2.2.1-AMD64-windows-mgw121
-- [E57] Building static library
-- Performing Test COMPILER_HAS_DEPRECATED_ATTR
-- Performing Test COMPILER_HAS_DEPRECATED_ATTR - Success
-- C:/msys64/home/Baba/Build/src/Base/TypePy.cpp
-- C:/msys64/home/Baba/Build/src/Base/BaseClassPy.cpp
-- C:/msys64/home/Baba/Build/src/Base/BoundBoxPy.cpp
-- C:/msys64/home/Baba/Build/src/Base/CoordinateSystemPy.cpp
-- C:/msys64/home/Baba/Build/src/Base/PersistencePy.cpp
-- C:/msys64/home/Baba/Build/src/Base/VectorPy.cpp
-- C:/msys64/home/Baba/Build/src/Base/MatrixPy.cpp
-- C:/msys64/home/Baba/Build/src/Base/RotationPy.cpp
-- C:/msys64/home/Baba/Build/src/Base/PlacementPy.cpp
-- C:/msys64/home/Baba/Build/src/Base/AxisPy.cpp
-- C:/msys64/home/Baba/Build/src/Base/UnitPy.cpp
-- C:/msys64/home/Baba/Build/src/Base/QuantityPy.cpp
-- C:/msys64/home/Baba/Build/src/App/DocumentPy.cpp
-- C:/msys64/home/Baba/Build/src/App/DocumentObjectPy.cpp
-- C:/msys64/home/Baba/Build/src/App/ExtensionPy.cpp
-- C:/msys64/home/Baba/Build/src/App/ExtensionContainerPy.cpp
-- C:/msys64/home/Baba/Build/src/App/DocumentObjectExtensionPy.cpp
-- C:/msys64/home/Baba/Build/src/App/GroupExtensionPy.cpp
-- C:/msys64/home/Baba/Build/src/App/LinkBaseExtensionPy.cpp
-- C:/msys64/home/Baba/Build/src/App/DocumentObjectGroupPy.cpp
-- C:/msys64/home/Baba/Build/src/App/GeoFeaturePy.cpp
-- C:/msys64/home/Baba/Build/src/App/GeoFeatureGroupExtensionPy.cpp
-- C:/msys64/home/Baba/Build/src/App/MetadataPy.cpp
-- C:/msys64/home/Baba/Build/src/App/OriginGroupExtensionPy.cpp
-- C:/msys64/home/Baba/Build/src/App/PartPy.cpp
-- C:/msys64/home/Baba/Build/src/App/ComplexGeoDataPy.cpp
-- C:/msys64/home/Baba/Build/src/App/PropertyContainerPy.cpp
-- C:/msys64/home/Baba/Build/src/App/MaterialPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Fem/App/FemMeshPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Fem/App/FemPostPipelinePy.cpp
-- Found OpenMP_C: -fopenmp (found version "4.5")
-- Found OpenMP_CXX: -fopenmp (found version "4.5")
-- Found OpenMP: TRUE (found version "4.5")
-- C:/msys64/home/Baba/Build/src/Mod/Fem/Gui/ViewProviderFemMeshPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Import/App/StepShapePy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Mesh/App/EdgePy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Mesh/App/FacetPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Mesh/App/MeshFeaturePy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Mesh/App/MeshPointPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Mesh/App/MeshPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Mesh/Gui/ViewProviderMeshPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/ArcPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/ArcOfConicPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/ArcOfCirclePy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/ArcOfParabolaPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/BodyBasePy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/ConicPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/CirclePy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/ArcOfEllipsePy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/EllipsePy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/HyperbolaPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/ArcOfHyperbolaPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/ParabolaPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/OffsetCurvePy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/GeometryPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/GeometryExtensionPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/GeometryIntExtensionPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/GeometryStringExtensionPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/GeometryBoolExtensionPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/GeometryDoubleExtensionPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/GeometryCurvePy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/BoundedCurvePy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/TrimmedCurvePy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/GeometrySurfacePy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/LinePy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/LineSegmentPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/PointPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/BezierCurvePy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/BSplineCurvePy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/PlanePy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/ConePy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/CylinderPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/SpherePy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/ToroidPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/BezierSurfacePy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/BSplineSurfacePy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/OffsetSurfacePy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/PlateSurfacePy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/RectangularTrimmedSurfacePy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/SurfaceOfExtrusionPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/SurfaceOfRevolutionPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/PartFeaturePy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/AttachExtensionPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/Part2DObjectPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/AttachEnginePy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/TopoShapePy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/TopoShapeCompoundPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/TopoShapeCompSolidPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/TopoShapeEdgePy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/TopoShapeFacePy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/TopoShapeShellPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/TopoShapeSolidPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/TopoShapeVertexPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/TopoShapeWirePy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/BRepOffsetAPI_MakePipeShellPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/BRepOffsetAPI_MakeFillingPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/PrecisionPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/BRepFeat/MakePrismPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/Geom2d/ArcOfCircle2dPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/Geom2d/ArcOfConic2dPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/Geom2d/ArcOfEllipse2dPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/Geom2d/ArcOfHyperbola2dPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/Geom2d/ArcOfParabola2dPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/Geom2d/BezierCurve2dPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/Geom2d/BSplineCurve2dPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/Geom2d/Circle2dPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/Geom2d/Conic2dPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/Geom2d/Ellipse2dPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/Geom2d/Geometry2dPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/Geom2d/Hyperbola2dPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/Geom2d/Curve2dPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/Geom2d/Line2dSegmentPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/Geom2d/Line2dPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/Geom2d/OffsetCurve2dPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/Geom2d/Parabola2dPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/GeomPlate/BuildPlateSurfacePy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/GeomPlate/CurveConstraintPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/GeomPlate/PointConstraintPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/HLRBRep/HLRBRep_AlgoPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/HLRBRep/HLRToShapePy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/HLRBRep/HLRBRep_PolyAlgoPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/HLRBRep/PolyHLRToShapePy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Part/App/ShapeUpgrade/UnifySameDomainPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/PartDesign/App/BodyPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/PartDesign/App/FeaturePy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/PartDesign/Gui/ViewProviderPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Path/App/CommandPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Path/App/PathPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Path/App/ToolPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Path/App/TooltablePy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Path/App/FeaturePathCompoundPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Path/App/AreaPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Path/App/FeatureAreaPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Path/App/VoronoiPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Path/App/VoronoiCellPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Path/App/VoronoiEdgePy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Path/App/VoronoiVertexPy.cpp
-- Found Boost: C:/msys64/mingw64/include (found version "1.79.0") found components: python39
-- found Boost: 1_79
-- boost-incude dirs are: C:/msys64/mingw64/include
-- boost-python lib is:
-- boost_LIBRARY_DIRS is: C:/msys64/mingw64/lib
-- Boost_LIBRARIES is: C:/msys64/mingw64/lib/libboost_python39-mt.dll.a
-- area module (for Path Workbench) will be installed to: lib
-- C:/msys64/home/Baba/Build/src/Mod/Path/PathSimulator/App/PathSimPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Points/App/PointsPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Robot/App/Robot6AxisPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Robot/App/TrajectoryPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Robot/App/WaypointPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Robot/App/RobotObjectPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Sketcher/App/SketchObjectSFPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Sketcher/App/SketchObjectPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Sketcher/App/SketchGeometryExtensionPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Sketcher/App/ExternalGeometryExtensionPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Sketcher/App/GeometryFacadePy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Sketcher/App/ExternalGeometryFacadePy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Sketcher/App/ConstraintPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Sketcher/App/SketchPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Spreadsheet/App/SheetPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Spreadsheet/App/PropertySheetPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Spreadsheet/App/PropertyColumnWidthsPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Spreadsheet/App/PropertyRowHeightsPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Spreadsheet/Gui/ViewProviderSpreadsheetPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/Measure/App/MeasurementPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/TechDraw/App/DrawPagePy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/TechDraw/App/DrawViewPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/TechDraw/App/DrawViewPartPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/TechDraw/App/DrawViewSymbolPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/TechDraw/App/DrawTemplatePy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/TechDraw/App/DrawParametricTemplatePy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/TechDraw/App/DrawSVGTemplatePy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/TechDraw/App/DrawViewClipPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/TechDraw/App/DrawViewDimensionPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/TechDraw/App/DrawViewDimExtentPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/TechDraw/App/DrawHatchPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/TechDraw/App/DrawGeomHatchPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/TechDraw/App/DrawViewCollectionPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/TechDraw/App/DrawProjGroupPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/TechDraw/App/DrawProjGroupItemPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/TechDraw/App/DrawViewAnnotationPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/TechDraw/App/DrawLeaderLinePy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/TechDraw/App/DrawRichAnnoPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/TechDraw/App/GeomFormatPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/TechDraw/App/CenterLinePy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/TechDraw/App/CosmeticEdgePy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/TechDraw/App/CosmeticVertexPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/TechDraw/App/DrawTilePy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/TechDraw/App/DrawTileWeldPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/TechDraw/App/DrawWeldSymbolPy.cpp
-- C:/msys64/home/Baba/Build/src/Mod/TechDraw/App/CosmeticExtensionPy.cpp
-- C:/msys64/home/Baba/Build/src/Gui/DocumentPy.cpp
-- C:/msys64/home/Baba/Build/src/Gui/PythonWorkbenchPy.cpp
-- C:/msys64/home/Baba/Build/src/Gui/ViewProviderPy.cpp
-- C:/msys64/home/Baba/Build/src/Gui/ViewProviderDocumentObjectPy.cpp
-- C:/msys64/home/Baba/Build/src/Gui/ViewProviderExtensionPy.cpp
-- C:/msys64/home/Baba/Build/src/Gui/WorkbenchPy.cpp
-- C:/msys64/home/Baba/Build/src/Gui/SelectionObjectPy.cpp
-- C:/msys64/home/Baba/Build/src/Gui/LinkViewPy.cpp
-- C:/msys64/home/Baba/Build/src/Gui/ViewProviderLinkPy.cpp
-- C:/msys64/home/Baba/Build/src/Gui/AxisOriginPy.cpp
-- C:/msys64/home/Baba/Build/src/Gui/CommandPy.cpp
Summary report
-- Build type:
-- Compiler: C:/msys64/mingw64/bin/c++.exe (12.1.0)
-- Flags: -Wall -Wextra -Wno-write-strings -Wno-attributes
-- Standard: Requires C++17
-- Python: 3.9.13 [C:/msys64/mingw64/bin/python3.9.exe] [.cp39-mingw_x86_64]
-- PCL: not enabled
-- pybind11: not enabled
-- Boost: 1.79.0 (107900)
-- XercesC: 3.2.3 [C:/msys64/mingw64/lib/libxerces-c.dll.a] [C:/msys64/mingw64/include]
-- ZLIB: 1.2.12
-- PyCXX: 6.2.8 [C:/msys64/home/Baba/FreeCAD/src]
-- OCC: 7.6.2 [TKFillet;TKMesh;TKernel;TKG2d;TKG3d;TKMath;TKIGES;TKSTL;TKShHealing;TKXSBase;TKBool;TKBO;TKBRep;TKTopAlgo;TKGeomAlgo;TKGeomBase;TKOffset;TKPrim;TKSTEPBase;TKSTEPAttr;TKSTEP209;TKSTEP;TKHLR;TKFeat] [C:/msys64/mingw64/lib] [C:/msys64/mingw64/include/opencascade]
-- SMESH: build internal
-- MEDFile: 4.1.1 [C:/msys64/mingw64/lib/libmedC.dll.a;C:/msys64/mingw64/lib/libmed.dll.a] [C:/msys64/mingw64/include]
-- HDF5: 1.12.2
-- VTK: 8.2.0
-- NETGEN: not enabled
-- SWIG: 4.0.2
-- Eigen3 3.4.0
-- Qt5Core: 5.15.3
-- Qt5Network: 5.15.3
-- Qt5Xml: 5.15.3
-- Qt5XmlPatterns: 5.15.3
-- Qt5Widgets: 5.15.3
-- Qt5PrintSupport: 5.15.3
-- Qt5OpenGL: 5.15.3
-- Qt5Svg: 5.15.3
-- Qt5UiTools: 5.15.3
-- Qt5Concurrent: 5.15.3
-- Qt5WebKitWidgets: 5.212.0
-- Designer plugin: not built per user request (BUILD_DESIGNER_PLUGIN)
-- Shiboken2: 5.15.4 [C:/msys64/mingw64/lib/cmake/Shiboken2-5.15.4] [C:/msys64/mingw64/include/shiboken2;C:/msys64/mingw64/include/python3.9]
-- PySide2: 5.15.4 [C:/msys64/mingw64/include/PySide2]
-- PySide2Tools: [C:/msys64/mingw64/bin/uic.exe] [C:/msys64/mingw64/bin/rcc.exe]
-- Freetype: 2.12.1
-- OpenGL: opengl32
-- OpenGLU: [glu32][]
-- Coin3D: 4.0.0 [C:/msys64/mingw64/lib/libCoin.dll.a] [C:/msys64/mingw64/include]
-- Pivy: 0.6.7
-- Matplotlib: 3.5.2
-- Rift: not enabled (BUILD_VR)
-- Doxygen: 1.9.4
-- Language: English
-- Coin3D_DOC: not found
Now run 'cmake --build C:/msys64/home/Baba/Build' to build FreeCAD
-- Configuring done
-- Generating done
-- Build files have been written to: C:/msys64/home/Baba/Build
They call me Baba, the bug master
Let us throw some stones into still waters
Yasser
Post
by Yasser » Tue Jun 14, 2022 6:54 pm
Gift wrote: ↑ Tue Jun 14, 2022 6:27 pm
next step
edit:
edit2:
You confused me !! this post for hdf5
and the error message you wrote i made another post for it
and YES i got the same message as yours.
but in the --build step not the cmake step
this post was about hdf5 and cmake only not the builds step this is why i confused.
Gift
Post
by Gift » Tue Jun 14, 2022 7:04 pm
Sorry for the confusion. Please read now the other topic.
Posts: 5552 Joined: Thu Apr 05, 2018 5:15 pm
Post
by adrianinsaval » Tue Jun 14, 2022 8:35 pm
next step
where did you had to add that?
Yasser
Post
by Yasser » Tue Jun 14, 2022 8:45 pm
adrianinsaval wrote: ↑ Tue Jun 14, 2022 8:35 pm
next step
In FreeCAD/CMakeList.txt
# include local modules
include(cMake/CMakePrintHelpers.cmake)
include(CheckCXXCompilerFlag)
include(AddFileDependencies)
include(cMake/FreeCadMacros.cmake)
# include helper functions/macros
add_subdirectory(cMake/FreeCAD_Helpers)
list(APPEND CMAKE_MODULE_PATH "${CMAKE_CURRENT_SOURCE_DIR}/cMake")
CompilerChecksAndSetups()
ConfigureCMakeVariables()
InitializeFreeCADBuildOptions()
CheckInterModuleDependencies()
FreeCADLibpackChecks()
SetupDoxygen()
Post
by adrianinsaval » Tue Jun 14, 2022 8:51 pm
we can't add that to the code though so I think Gift's solution is the more general one, how is that variable normally set in other systems? shouldn't msys set that?
Yasser
Post
by Yasser » Tue Jun 14, 2022 9:06 pm
adrianinsaval wrote: ↑ Tue Jun 14, 2022 8:51 pm
And why you can't add?
and What other systems?
you are appending to the variable without deleting others (if exists).
also Gift's solution is very nice indeed.
Post
by adrianinsaval » Tue Jun 14, 2022 9:14 pm
for some reason I missed the fact you were appending not assigning
however I'm still not sure if it's the right way as that is a harcoded path, can't people install mingw in other paths? And doesn't that interfere if you want to make a msvc compilation but also have mingw installed? By other systems I mean linux, mac and windows with msvc
