I'm using msys2 (MinGW 64) on Windows 7 sp1 to compile and build FreeCAD 0.20 Beta1
i downloaded the source code then started to build
but,
i faced two errors till now one i solved (i will talk about it later) and the other not yet
As described in the picture
hdf5 library needs to be defined to cmake but how ??
i guess the library of hdf5 exists in MinGW/bin ??
>>>>>>>>>>>>>>>>>>>>> here is the error
CMake Error at cMake/FreeCAD_Helpers/SetupSalomeSMESH.cmake:79 (find_package):
Could not find a package configuration file provided by "HDF5" with any of
the following names:
HDF5Config.cmake
hdf5-config.cmake
Add the installation prefix of "HDF5" to CMAKE_PREFIX_PATH or set
"HDF5_DIR" to a directory containing one of the above files. If "HDF5"
provides a separate development package or SDK, be sure it has been
installed.
Call Stack (most recent call first):
CMakeLists.txt:58 (SetupSalomeSMESH)
-- Configuring incomplete, errors occurred!
