Selecting Windows SDK version 10.0.19041.0 to target Windows 10.0.19042.
Compiler: MSVC, version: 19.29.30138.0
prefix: C:/FC_Local
bindir: bin
datadir: data
docdir: doc
includedir: include
libdir: lib
cmake: 3.15.7
PyCXX found:
Headers: C:/FC_Bld/Code/src
Sources: C:/FC_Bld/Code/src/CXX
Version: 6.2.8
Could NOT find Doxygen (missing: DOXYGEN_EXECUTABLE)
Doxygen not found, will not build documentation.
PyCXX found:
Version: 6.2.8
-- Found OCE/OpenCASCADE version: 7.5.3
-- OCE/OpenCASCADE include directory: C:/FC_Bld/Build/FreeCADLibs_12.5.4_x64_VC17/inc
-- OCE/OpenCASCADE shared libraries directory: C:/FC_Bld/Build/FreeCADLibs_12.5.4_x64_VC17/lib
HUHUH: C:/FC_Bld/Build/FreeCADLibs_12.5.4_x64_VC17/lib/cmake/vtk-8.2/VTKTargets.cmake
VTK components: vtkCommonCore;vtkCommonDataModel;vtkFiltersVerdict;vtkIOXML;vtkFiltersCore;vtkFiltersGeneral;vtkIOLegacy;vtkFiltersExtraction;vtkFiltersSources;vtkFiltersGeometry;vtkhdf5;vtkRenderingCore;vtkInteractionStyle;vtkRenderingFreeType;vtkRenderingOpenGL2
Check for medfile (libmed and libmedc) ...
Found Boost: C:/FC_Bld/Build/FreeCADLibs_12.5.4_x64_VC17/include (found suitable version "1.67.0", minimum required is "1.55") found components: filesystem program_options regex system thread date_time chrono atomic
Found Netgen: C:/FC_Bld/Build/FreeCADLibs_12.5.4_x64_VC17/cmake
Found NETGEN version 6.2, calculated: 395734
Coin3D libraries found
ModuleNotFoundError: No module named 'pivy'
Shiboken2Config: Using default python: .cp38-win_amd64
SHIBOKEN_PYTHON_INCLUDE_DIRS computed to value: 'C:/Program Files/Python38/include'
SHIBOKEN_PYTHON_LIBRARIES computed to value: ''
libshiboken built for Release
ModuleNotFoundError: No module named 'PySide2'
PySide2 Python module not found.
Matplotlib not found, Plot module won't be available.
Platform is 64-bit, set -D_OCC64
[E57] Revison ID: E57Format-2.2.1-AMD64_64-windows
[E57] Building static library
Performing Test _flag_found
Performing Test _flag_found - Failed
Could NOT find OpenMP_C (missing: OpenMP_C_FLAGS OpenMP_C_LIB_NAMES)
Could NOT find OpenMP_CXX (missing: OpenMP_CXX_FLAGS OpenMP_CXX_LIB_NAMES)
Could NOT find OpenMP (missing: OpenMP_C_FOUND OpenMP_CXX_FOUND)
Found Boost: C:/FC_Bld/Build/FreeCADLibs_12.5.4_x64_VC17/include (found version "1.67.0") found components: python38
found Boost: 1_67
boost-incude dirs are: C:/FC_Bld/Build/FreeCADLibs_12.5.4_x64_VC17/include
boost-python lib is:
boost_LIBRARY_DIRS is: C:/FC_Bld/Build/FreeCADLibs_12.5.4_x64_VC17/lib
Boost_LIBRARIES is: optimizedC:/FC_Bld/Build/FreeCADLibs_12.5.4_x64_VC17/lib/boost_python38-vc141-mt-x64-1_67.libdebugC:/FC_Bld/Build/FreeCADLibs_12.5.4_x64_VC17/lib/boost_python38-vc141-mt-gd-x64-1_67.lib
area module (for Path Workbench) will be installed to: lib
Summary report
Compiler: C:/Program Files (x86)/Microsoft Visual Studio/2019/Community/VC/Tools/MSVC/14.29.30133/bin/Hostx64/x64/cl.exe (19.29.30138.0)
Flags: /DWIN32 /D_WINDOWS /W3 /GR /EHsc /MP
Standard: Requires C++17
Python: 3.8.8 [C:/Program Files/Python38/python.exe] [.cp38-win_amd64]
PCL: not enabled
pybind11: not enabled
Boost: 1.67.0 (106700)
XercesC: 3.2.2 [optimized;C:/FC_Bld/Build/FreeCADLibs_12.5.4_x64_VC17/lib/xerces-c_3.lib;debug;C:/FC_Bld/Build/FreeCADLibs_12.5.4_x64_VC17/lib/xerces-c_3D.lib] [C:/FC_Bld/Build/FreeCADLibs_12.5.4_x64_VC17/include]
ZLIB: 1.2.11
PyCXX: 6.2.8 [C:/FC_Bld/Code/src]
OCC: 7.5.3 [TKFillet;TKMesh;TKernel;TKG2d;TKG3d;TKMath;TKIGES;TKSTL;TKShHealing;TKXSBase;TKBool;TKBO;TKBRep;TKTopAlgo;TKGeomAlgo;TKGeomBase;TKOffset;TKPrim;TKSTEPBase;TKSTEPAttr;TKSTEP209;TKSTEP;TKHLR;TKFeat] [C:/FC_Bld/Build/FreeCADLibs_12.5.4_x64_VC17/lib] [C:/FC_Bld/Build/FreeCADLibs_12.5.4_x64_VC17/inc]
SMESH: build internal
MEDFile: 4.0.0 [C:/FC_Bld/Build/FreeCADLibs_12.5.4_x64_VC17/lib/medC.lib] [C:/FC_Bld/Build/FreeCADLibs_12.5.4_x64_VC17/include]
HDF5:
VTK: 8.2.0
NETGEN: 6.2.2006 (6.2.2006-19-gb37a3e6c) [-DNO_PARALLEL_THREADS;-DOCCGEOMETRY;-DNETGEN_VERSION=395734] [] [C:/FC_Bld/Build/FreeCADLibs_12.5.4_x64_VC17/include/include;C:/FC_Bld/Build/FreeCADLibs_12.5.4_x64_VC17/include] [nglib] [C:/FC_Bld/Build/FreeCADLibs_12.5.4_x64_VC17/include/include;C:/FC_Bld/Build/FreeCADLibs_12.5.4_x64_VC17/include]
SWIG: 4.0.2
Eigen3 3.3.90
Qt5Core: 5.15.2
Qt5Network: 5.15.2
Qt5Xml: 5.15.2
Qt5XmlPatterns: 5.15.2
Qt5Widgets: 5.15.2
Qt5PrintSupport: 5.15.2
Qt5OpenGL: 5.15.2
Qt5Svg: 5.15.2
Qt5UiTools: 5.15.2
Qt5Concurrent: 5.15.2
Qt5WebEngineWidgets: 5.15.2
Qt5WinExtras: 5.15.2
Shiboken2: 5.15.0 [C:/FC_Bld/Build/FreeCADLibs_12.5.4_x64_VC17/lib/cmake/Shiboken2-5.15.0] [C:/FC_Bld/Build/FreeCADLibs_12.5.4_x64_VC17/include/shiboken2;C:/Program Files/Python38/include]
PySide2: 5.15.0 [C:/FC_Bld/Build/FreeCADLibs_12.5.4_x64_VC17/include/PySide2]
PySide2Tools: [C:/FC_Bld/Build/FreeCADLibs_12.5.4_x64_VC17/bin/uic.exe] [C:/FC_Bld/Build/FreeCADLibs_12.5.4_x64_VC17/bin/rcc.exe]
Freetype: 2.10.1
OpenGL: opengl32
OpenGLU: [glu32][]
Coin3D: 4.0.1 [optimized;C:/FC_Bld/Build/FreeCADLibs_12.5.4_x64_VC17/lib/Coin4.lib;debug;C:/FC_Bld/Build/FreeCADLibs_12.5.4_x64_VC17/lib/Coin4d.lib] [C:/FC_Bld/Build/FreeCADLibs_12.5.4_x64_VC17/include]
Pivy:
Matplotlib: not found
Rift: not enabled (BUILD_VR)
Doxygen: not found
Created install commands for INSTALL target.
Now run 'cmake --build C:/FC_Bld/Build' to build FreeCAD
Configuring done
