Unable to run FreeCad `GLIBCXX_3.4.29' not found'
Ank
Post by Ank »
This is the error, with extra LIBGL debugging:
$ DISPLAY=:0 LIBGL_DEBUG=verbose ./FreeCAD_0.19-24291-Linux-Conda_glibc2.12-x86_64.AppImage
FreeCAD 0.19, Libs: 0.19R24291 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre and others 2001-2021
FreeCAD is free and open-source software licensed under the terms of LGPL2+ license.
FreeCAD wouldn't be possible without FreeCAD community.
libGL: Can't open configuration file /home/andre/.drirc: No such file or directory.
libGL: using driver i915 for 10
libGL: pci id for fd 10: 8086:3e98, driver iris
libGL: MESA-LOADER: failed to open /usr/lib/x86_64-linux-gnu/dri/iris_dri.so: /tmp/.mount_FreeCARlCF1O/usr/bin/../lib/libstdc++.so.6: version `GLIBCXX_3.4.29' not found (required by /usr/lib/x86_64-linux-gnu/dri/iris_dri.so)
libGL: MESA-LOADER: failed to open \$${ORIGIN}/dri/iris_dri.so: \$${ORIGIN}/dri/iris_dri.so: cannot open shared object file: No such file or directory
libGL: MESA-LOADER: failed to open /usr/lib/dri/iris_dri.so: /usr/lib/dri/iris_dri.so: cannot open shared object file: No such file or directory
libGL error: MESA-LOADER: failed to open iris: /usr/lib/dri/iris_dri.so: cannot open shared object file: No such file or directory (search paths /usr/lib/x86_64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri, suffix _dri)
libGL error: failed to load driver: iris
libGL: MESA-LOADER: failed to open /usr/lib/x86_64-linux-gnu/dri/swrast_dri.so: /tmp/.mount_FreeCARlCF1O/usr/bin/../lib/libstdc++.so.6: version `GLIBCXX_3.4.29' not found (required by /usr/lib/x86_64-linux-gnu/dri/swrast_dri.so)
libGL: MESA-LOADER: failed to open \$${ORIGIN}/dri/swrast_dri.so: \$${ORIGIN}/dri/swrast_dri.so: cannot open shared object file: No such file or directory
libGL: MESA-LOADER: failed to open /usr/lib/dri/swrast_dri.so: /usr/lib/dri/swrast_dri.so: cannot open shared object file: No such file or directory
libGL error: MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: cannot open shared object file: No such file or directory (search paths /usr/lib/x86_64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri, suffix _dri)
libGL error: failed to load driver: swrast
/tmp/.mount_FreeCARlCF1O/AppRun: line 41: 10824 Aborted                 (core dumped) ${MAIN} "$@"
Ubuntu 21.10 , with Intel graphics:
00:00.0 Host bridge: Intel Corporation 8th/9th Gen Core 8-core Desktop Processor Host Bridge/DRAM Registers [Coffee Lake S] (rev 0d)
00:02.0 VGA compatible controller: Intel Corporation CoffeeLake-S GT2 [UHD Graphics 630] (rev 02)
00:08.0 System peripheral: Intel Corporation Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th/8th Gen Core Processor Gaussian Mixture Model
00:12.0 Signal processing controller: Intel Corporation Cannon Lake PCH Thermal Controller (rev 10)
Please advise.
bambuko
Re: Unable to run FreeCad `GLIBCXX_3.4.29' not found'
Post by bambuko »
I had similar problems trying FreeCAD 0.20 on elementary OS (based on Ubuntu 20.04 LTS atop Linux 5.11 kernel).
Updating graphics drivers solve the problem:
https://forum.freecadweb.org/viewtopic.php?f=4&t=63225
I am using Link branch and Assembly3
you can also download ... and try it here
excellent Assembly3 tutorials here
try this: https://forum.freecadweb.org/viewtopic. ... 51#p510504
you'll need appimagetool, you can download it here: https://github.com/AppImage/AppImageKit/releases/tag/13
the issues come from incompatible libstdc++ versions in the system an the appimage, soon FreeCAD 0.19.3 is going to be released and that bug will likely be resolved
