Just for completeness, if someone have the same issue. Today i updated my Debian (nothing special, see list) and now the issue is solved. I have no idea which package update solved the issue. The update only updates something for internet/domain, video ffmpeg and openjdk, ..... funny.
bind9-dnsutils (1:9.16.15-1) to 1:9.16.22-1~deb11u1
bind9-host (1:9.16.15-1) to 1:9.16.22-1~deb11u1
bind9-libs (1:9.16.15-1) to 1:9.16.22-1~deb11u1
ffmpeg (7:4.3.2-0+deb11u2) to 7:4.3.3-0+deb11u1
libavcodec-dev (7:4.3.2-0+deb11u2) to 7:4.3.3-0+deb11u1
libavcodec58 (7:4.3.2-0+deb11u2) to 7:4.3.3-0+deb11u1
libavcodec58:i386 (7:4.3.2-0+deb11u2) to 7:4.3.3-0+deb11u1
libavdevice58 (7:4.3.2-0+deb11u2) to 7:4.3.3-0+deb11u1
libavfilter7 (7:4.3.2-0+deb11u2) to 7:4.3.3-0+deb11u1
libavformat-dev (7:4.3.2-0+deb11u2) to 7:4.3.3-0+deb11u1
libavformat58 (7:4.3.2-0+deb11u2) to 7:4.3.3-0+deb11u1
libavresample4 (7:4.3.2-0+deb11u2) to 7:4.3.3-0+deb11u1
libavresample4:i386 (7:4.3.2-0+deb11u2) to 7:4.3.3-0+deb11u1
libavutil-dev (7:4.3.2-0+deb11u2) to 7:4.3.3-0+deb11u1
libavutil56 (7:4.3.2-0+deb11u2) to 7:4.3.3-0+deb11u1
libavutil56:i386 (7:4.3.2-0+deb11u2) to 7:4.3.3-0+deb11u1
libjavascriptcoregtk-4.0-18 (2.32.4-1~deb11u1) to 2.34.1-1~deb11u1
libpostproc55 (7:4.3.2-0+deb11u2) to 7:4.3.3-0+deb11u1
libswresample-dev (7:4.3.2-0+deb11u2) to 7:4.3.3-0+deb11u1
libswresample3 (7:4.3.2-0+deb11u2) to 7:4.3.3-0+deb11u1
libswresample3:i386 (7:4.3.2-0+deb11u2) to 7:4.3.3-0+deb11u1
libswscale-dev (7:4.3.2-0+deb11u2) to 7:4.3.3-0+deb11u1
libswscale5 (7:4.3.2-0+deb11u2) to 7:4.3.3-0+deb11u1
libwebkit2gtk-4.0-37 (2.32.4-1~deb11u1) to 2.34.1-1~deb11u1
openjdk-11-jdk (11.0.12+7-2) to 11.0.13+8-1~deb11u1
openjdk-11-jdk-headless (11.0.12+7-2) to 11.0.13+8-1~deb11u1
openjdk-11-jre (11.0.12+7-2) to 11.0.13+8-1~deb11u1
openjdk-11-jre-headless (11.0.12+7-2) to 11.0.13+8-1~deb11u1
wmayer wrote: ↑Sun Nov 21, 2021 1:16 pm
You should pass -DBUILD_FEM=0 to cmake or simply use cmake-gui where you can disable it with unticking a check box.
Thank you for your hint.
Since passing any options to cmake is not straightforward in gentoo's portage, I digged deeper into the build process and build logs. Judging the build log file, the use flag does indeed influence the build!
'-fem' switches '-DBUILDFEM=yes' to '-DBUILDFEM=no' and makes some more fem-related entries disappearing.
oxensepp wrote: ↑Sun Nov 21, 2021 4:43 pm
Unfortunately, the error stays untouched.
Will try to downgrade OCCT now.
Done
Now, I have opencascade-7.5.3-r3. freecad ("FreeCAD 0.19 Revision: Unknown", but gentoo calls it 0.19.2-r4) compiled and starts.
By the way, at some point opencascade was installed twice, 7.5.3-r3 and 7.6.0_beta. I removed both and installed again 7.5.3-r3, for ensuring that only the 7.5.3-r3 was available.
