Appimage problems in Fedora 34
Re: Appimage problems in Fedora 34
looo wrote: Sun Jun 20, 2021 12:20 am The issue is with the conda-forge libatdc++ library which needs to be updated. In general conda-packages should work with any distribution, but is not fully independent of the system. So new distros might add some issues to conda-packages.
I guess we will see a solution in the next months. But I am not sure if they really actively work on this issue yet.
looo, whats the url for that conda-forge repo?
Edit: I've updated the weekly-builds page (https://github.com/FreeCAD/FreeCAD-Bund ... kly-builds) with workaround instructions kindly provided by @xuewenbao (Thanks!)
xuewenbao wrote: Wed Jun 16, 2021 7:36 am hope it will help you
looo
Post by looo »
Kunda1 wrote: Tue Jul 06, 2021 1:05 am
Thanks @kunda. There were a short discussion in the conda-forge gitter chat. There is a grant from numfocus targeting the update of the compiler tools (which also includes the update of libstdc++).
herbk
Post by herbk »
Hi looo,
looo wrote: Thu Jul 08, 2021 9:07 am ping...
if just deleting this files works,- wouldn't it be possible to exclude it before creating the AppImage ?
And at general: If deliting it dosn't metter, why are this files part of the AppImage ?
Gruß Herbert
looo
Post by looo »
herbk wrote: Fri Jul 09, 2021 3:04 pm Hi looo,
Are you sure this will work in general?
herbk
Post by herbk »
No, i'm not, - but the workaround suggests it to me...
Gruß Herbert
herbk wrote: Fri Jul 09, 2021 4:25 pm No, i'm not, - but the workaround suggests it to me...
My guess, i think that the workaround (deleting the files) forces the AppImage to use the local system files. So I'm not sure that can be applied for general use. We could experiment I guess?
herbk
Post by herbk »
Kunda1 wrote: Fri Jul 09, 2021 6:02 pm
You are guessing right : if i delete the local systems files FC dos't start up at all...
What i noticed at this: My system dont't have a libstdc++.so, only a libstdc++.so.6 and a libstdc++.so.6.0.29 . The libstdc++.so.6 seams to be a link (simlink? whats the different?) which points to libstdc++.so.6.0.29.
One thing more:
The Problem dos also exist with the AppImage of the FC stable ! May be you should add the hint at the download page of the stable to..
Gruß Herbert
And maybe we should rebuild stable and publish it once conda updates this files, would having a newer version of that library make it fail if the distro has an older version?
xuewenbao
Post by xuewenbao »
sol1d wrote: Thu Jun 17, 2021 3:13 pm That worked for me on Arch Linux as well, thanks for the hint!
Would you mind sharing how did you get to that idea?
I am very happy it can help, I got the idea from the link below:
https://pixinsight.com/forum/index.php? ... -34.16520/
herbk
Post by herbk »
at least at OpenSuse Tumbleweed the Problem is solved !
But it looks to me like it is solved by the last BS Update i made, because also old Appimages, which dosn*t work before, are working now as expected.
Gruß Herbert
