FreeCAD 0.19: macOS Big Sur
Anno Me Nuehm
Post by Anno Me Nuehm »
I'm running macOS 11.0 Beta (Big Sur) on my Mac for some time now. Prior to upgrading to Big Sur I had macOS Catalina deployed, in conjunction with FreeCAD 0.19.
FreeCAD 0.19 with Catalina worked like a charm, but after migrating to Big Sur, FreeCAD 0.19 ceased to work. Whenever launching FC it is getting stuck. Reverting to FC 0.18, and all is working perfectly fine.
When digging into the system logs, some FC-related lines pop up.
Oct 20 10:18:20 My-Mac freecad[83655]: getattrlist failed for /System/Library/Extensions/AppleIntelHD5000GraphicsGLDriver.bundle/Contents/MacOS/AppleIntelHD5000GraphicsGLDriver: #2: No such file or directory
Oct 20 10:18:20 My-Mac-03 freecad[83655]: getattrlist failed for /System/Library/Frameworks/OpenGL.framework/Resources//GLRendererFloat.bundle/GLRendererFloat: #2: No such file or directory
Having a look around in the directories listed, the directories can be found, but the files mentioned are missing.
Is there anything I can do to tackle this one and get FC 0.19 up & running again?
-- Anno
Re: FreeCAD 0.19: macOS Big Sur: stuck on launch
Hi and welcome to the forum!
Apple doesn't support OpenGL anymore. On their official list of supported hardware are some computers already missing. I'm afraid you are a victim of that politic, and the fact that 0.19 uses different libraries.
Anno Me Nuehm
Thanks!
Question begging: is FC 0.18 not using OpenGL?
If it does then how comes FC 0.18 is working on macOS 11, but FC 0.19 doesn't?
I understand that the assembly4 workbench requires FC 0.19? So sticking with FC 0.18 wouldn't be an option, would it?
Anno Me Nuehm wrote: Tue Oct 20, 2020 1:59 pm Question begging: is FC 0.18 not using OpenGL?
It does use OpenGL as well
I am neither familiar with the Appl-OpenGL politics not am I an OpenGL specialist or an Qt expert. But I can imagine that with 0.19 the libraries use different functions. Many things concerning driver issues have vanished in 0.19, so they shure changed some internals. For more details you may ask Apple about their OpenGL support.
vejmarie
Post by vejmarie »
How did you installed 0.19 ? I am interested to have a look to this issue. I am running 0.19 on Big Sur beta without any issue, but I am using a MacPro (the bathroom trashcan)
Anno Me Nuehm
I've just downloaded the dmg from the FC web site, copied the FC app to a local directory, and launched it from there. Then I had to accept an exception to the privacy rules as the app originated from an unidentified developer.
On my Mac Mini I'm having installed several things, amongst others home brew & pyenv.
The MacPro 2019 is still listed here, while the current MacBookPro is not: https://support.apple.com/de-de/HT202823.
This program may help to identify the capabilities concerning OpenGL: https://apps.apple.com/de/app/opengl-ex ... 2073?mt=12.
This is what it shows on my MacBook Pro with MacOS 10.15.7:
Bildschirmfoto 2020-10-20 um 21.09.53.png (88.69 KiB) Viewed 61610 times
vejmarie
Post by vejmarie »
Anno Me Nuehm wrote: Tue Oct 20, 2020 7:00 pm Hi,
I suspect this is more an XCode / OS build time related issue than anything else especially if 0.18 works. If you want to give a try to the homebrew build and let me know if that works better. be aware that the installation might be requiring that your recompile opencascade and freecad to support properly BigSur. It take times, but it will work I am pretty convinced.
Anno Me Nuehm
vejmarie wrote: Tue Oct 20, 2020 11:22 pm I suspect this is more an XCode / OS build time related issue than anything else especially if 0.18 works. If you want to give a try to the homebrew build and let me know if that works better. be aware that the installation might be requiring that your recompile opencascade and freecad to support properly BigSur. It take times, but it will work I am pretty convinced.
Do I need the qt5 development files (headers, libraries) for the re-compiling of FC?
How would I go about tapping the FC 0.19 branch?
