FreeCad IfcOpenShell and Ubuntu
cobo
Post by cobo »
I am having trouble to install FreeCad with IfcOpenShell on Ubuntu 18.04.
Reading IFC files is actually for me the main purpose why I installed FreeCAD at all, but opening an IFC file always fails with the message "IfcOpenShell was not found on this system: IFC support is disabled". (I had to do this many times until I could read it once because that message disappears always after less time than what it takes for me to read even half the sentence...).
The version of FreeCAD I have installed seems to be recent: 0.18.4.
It comes with an addon manager, but that does not mention anything about adding IFC support.
Then I followed some instructions to add some freecad-community package to the apt installation system. Doing so warns that this is obsolete because FreeCAD does have an addon manager now. Ok, I have seen that, but it does not give me what I need, so I added that package anyway.
With that I was able to install IFC Open Shell with "sudo apt install ifcopenshell0" (only adding a zero at the end!) successfully.
But anyway - FreeCAD gives me the same error message - and now I am a bit lost:
Is there some instructions how to get a working FreeCAD/IfcOpenShell combination running on Ubuntu 18.04?
Re: FreeCad IfcOpenShell and Ubuntu
Hi and welcome to the forum!
You can see the message permanently in View->Panels->Report view.
sgrogan
Post by sgrogan »
cobo wrote: Sun May 31, 2020 11:10 am Is there some instructions how to get a working FreeCAD/IfcOpenShell combination running on Ubuntu 18.04?
Download the version that matches your system from here: https://github.com/IfcOpenBot/IfcOpenSh ... f8b638436a (scroll to the bottom of the page)
and extract to /usr/lib/python3/dist-packages (I think you will need sudo)
You can uninstall ifcopenshell0 from the PPA.
"fight the good fight"
cobo
Post by cobo »
Thanks for the advice: worked perfectly now!
At the same time I learned that IfcOpenShell is basically just a Python module.
FreecadVin
Post by FreecadVin »
Hi, Importing ifcOpenShell into Freecad 19 snap hasn't worked for me yet. Can anyone tell me how I can make this work please?
What I tried several is copying the ifcOpenShell folder (the linux 64bit, found on github(above) and the .org version v0.6.0) everywhere I could find a python 3.8 folder. But Freecad keeps telling me I'm not succeeding. :)
The message on the python console:
>>> import ifcOpenShell
ModuleNotFoundError: No module named 'ifcOpenShell'
My system:
OS: Ubuntu Core 20 (ubuntu:GNOME/ubuntu)
Version: 0.19.24276 (Git)
Build type: Unknown
Branch: releases/FreeCAD-0-19
Hash: a88db11e0a908f6e38f92bfc5187b13ebe470438
Python version: 3.8.5
Qt version: 5.12.8
OCC version: 7.5.0
Python console information:
>>> import sys
>>> print(sys.path)
['/snap/freecad/22/usr/lib/python3/dist-packages/git/ext/gitdb', '/home/vincent/snap/freecad/22/.FreeCAD/Mod/BIM', '/home/vincent/snap/freecad/22/.FreeCAD/Mod/BCFPlugin', '/home/vincent/snap/freecad/22/.FreeCAD/Mod/Reinforcement', '/home/vincent/snap/freecad/22/.FreeCAD/Mod/dxf-library', '/home/vincent/snap/freecad/22/.FreeCAD/Mod/BIMBots', '/home/vincent/snap/freecad/22/.FreeCAD/Mod/bimtester', '/home/vincent/snap/freecad/22/.FreeCAD/Mod/Glass', '/home/vincent/snap/freecad/22/.FreeCAD/Mod/CADExchanger', '/snap/freecad/22/opt/local/FreeCAD-0.19/Mod/Web', '/snap/freecad/22/opt/local/FreeCAD-0.19/Mod/Tux', '/snap/freecad/22/opt/local/FreeCAD-0.19/Mod/Test', '/snap/freecad/22/opt/local/FreeCAD-0.19/Mod/TechDraw', '/snap/freecad/22/opt/local/FreeCAD-0.19/Mod/Surface', '/snap/freecad/22/opt/local/FreeCAD-0.19/Mod/Start', '/snap/freecad/22/opt/local/FreeCAD-0.19/Mod/Spreadsheet', '/snap/freecad/22/opt/local/FreeCAD-0.19/Mod/Sketcher', '/snap/freecad/22/opt/local/FreeCAD-0.19/Mod/Show', '/snap/freecad/22/opt/local/FreeCAD-0.19/Mod/Robot', '/snap/freecad/22/opt/local/FreeCAD-0.19/Mod/ReverseEngineering', '/snap/freecad/22/opt/local/FreeCAD-0.19/Mod/Raytracing', '/snap/freecad/22/opt/local/FreeCAD-0.19/Mod/Points', '/snap/freecad/22/opt/local/FreeCAD-0.19/Mod/Path', '/snap/freecad/22/opt/local/FreeCAD-0.19/Mod/PartDesign', '/snap/freecad/22/opt/local/FreeCAD-0.19/Mod/Part', '/snap/freecad/22/opt/local/FreeCAD-0.19/Mod/OpenSCAD', '/snap/freecad/22/opt/local/FreeCAD-0.19/Mod/MeshPart', '/snap/freecad/22/opt/local/FreeCAD-0.19/Mod/Mesh', '/snap/freecad/22/opt/local/FreeCAD-0.19/Mod/Measure', '/snap/freecad/22/opt/local/FreeCAD-0.19/Mod/Material', '/snap/freecad/22/opt/local/FreeCAD-0.19/Mod/Inspection', '/snap/freecad/22/opt/local/FreeCAD-0.19/Mod/Import', '/snap/freecad/22/opt/local/FreeCAD-0.19/Mod/Image', '/snap/freecad/22/opt/local/FreeCAD-0.19/Mod/Idf', '/snap/freecad/22/opt/local/FreeCAD-0.19/Mod/Fem', '/snap/freecad/22/opt/local/FreeCAD-0.19/Mod/Drawing', '/snap/freecad/22/opt/local/FreeCAD-0.19/Mod/Draft', '/snap/freecad/22/opt/local/FreeCAD-0.19/Mod/Cloud', '/snap/freecad/22/opt/local/FreeCAD-0.19/Mod/Arch', '/snap/freecad/22/opt/local/FreeCAD-0.19/Mod/AddonManager', '/snap/freecad/22/opt/local/FreeCAD-0.19/Mod', '/snap/freecad/22/opt/local/FreeCAD-0.19/lib', '/snap/freecad/22/opt/local/FreeCAD-0.19/Ext', '/snap/freecad/22/opt/local/FreeCAD-0.19/bin', '/snap/freecad/22/usr/lib/python38.zip', '/snap/freecad/22/usr/lib/python3.8', '/snap/freecad/22/usr/lib/python3.8/lib-dynload', '/snap/freecad/22/usr/lib/python3/dist-packages', '/home/vincent/snap/freecad/22/.FreeCAD/Macro', '/snap/freecad/22/opt/local/FreeCAD-0.19/Macro', '/snap/freecad/22/usr/lib/python3/dist-packages/gitdb/ext/smmap']
Syres
Post by Syres »
FreecadVin wrote: Tue Sep 21, 2021 9:47 am >>> import ifcOpenShell
That would never work even if IFC is installed correctly (it's case sensitive), the correct test is:
import ifcopenshell
The other two modules that I'm aware of are:
import importIFCHelper
import importIFCmulticore
FreecadVin
Thank you for trying to help me. 8-)
>>> import ifcopenshell
ModuleNotFoundError: No module named 'ifcopenshell'
Still no luck, the importIFCHelper and importIFCmulticore do nothing. No error message nothing.
Shouldn't the ifcopenshell be installed (copied) into the snap. Unfortunedly I can't do that. As I'm not the snap-owner.
So if I install Freecad weekly builds appimage from https://github.com/FreeCAD/FreeCAD-Bund ... kly-builds I could use ifcopenshell?
Syres
Post by Syres »
FreecadVin wrote: Wed Sep 22, 2021 11:13 am So if I install Freecad weekly builds appimage from https://github.com/FreeCAD/FreeCAD-Bund ... kly-builds I could use ifcopenshell?
Yes, I believe ifcopenshell is part of the AppImage, it's a long while since I used it as I compile FC on my Linux partition.
bje
Post by bje »
FreecadVin wrote: Tue Sep 21, 2021 9:47 am Hi, Importing ifcOpenShell into Freecad 19 snap hasn't worked for me yet. Can anyone tell me how I can make this work please?
I got it working by putting the ifcopenshell directory under ~/snap/freecad/current/.FreeCAD/Mod/BIM. That directory is in the default Python module search path according to the Python console.
bernd
Post by bernd »
BTW: FreeCAD 0.18 is outdated. There have been hundreds of fixes in the regard of ifc export and import.
It is recommended to use latest version if you work with ifc.
BTW: If you are able to compile FreeCAD yourself, it is easy to compile ifcopenshell too.
Latest ifcopenshell can be downloaded here. https://github.com/IfcOpenBot/IfcOpenSh ... its/v0.6.0 search for the newest commit which has a comment. This comment will be the binary to download for various OS and python versions.
cheers bernd
