New libpacks for Windows with Qt5.15, OCC7.5
Re: New libpacks for Windows with Qt5.15, OCC7.5
To make sure my config files weren't having some strange impact, I scrapped them for this test.
I loaded up the new FreeCAD_0.19.24047_Win-LPv12.4.3_vc17.x-x86-64 build and changed my background colour with no stylesheet, all responded fine. Then I applied the bundled Behave-Dark stylesheet and repeated the background colour change, OK button on each window appear to not respond for a few seconds.
Repeat exercise using 'old LP' build FreeCAD_0.19.24047_Win-LPv12.1.6_vc14.x-x86-64 and response is near instant as expected.
I experience a crash when loading the Mesh WB:
https://forum.freecadweb.org/viewtopic.php?f=3&t=55665
Version: 0.19.24097 (Git)
Hash: 48dc4063f80c1e1d65d6a98d81b24308b0bf28e9
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
I do not experience that. The only thing I notice is that with the mentioned theme you have to click on the actual text of a button. Clicking on the area around it will highlight the button, but then nothing happens.
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
OS: Windows 8.1 (6.3)
Python version: 3.6.8
Qt version: 5.12.1
After updating Visual Studio to 16.8.5 I get these errors when trying to compile FreeCAD:apeltauer wrote: ping
Severity Code Description Project File Line Suppression State
Error C1853 'FreeCADApp.dir\Release\\FreeCADApp.pch' precompiled header file is from a different version of the compiler, or the precompiled header is C++ and you are using it from C (or vice versa) FreeCADApp E:\FC_Bld\Code_kiss\src\App\Application.cpp 26
Error C1853 'FreeCADGui.dir\Release\\FreeCADGui.pch' precompiled header file is from a different version of the compiler, or the precompiled header is C++ and you are using it from C (or vice versa) FreeCADGui E:\FC_Bld\Code_kiss\src\Gui\Tree.cpp 24
I built for Windows 10 using Libpack v12.4.3_x64_VC17.
The icons in the Draft Workbench Snap Toolbar are blank, but the functionality (e.g. tool-tips etc) appears to be present.
Internet search suggest (for Linux) this can occur when library 'python3-pyqt5' is missing, and suggest the solution is to "add the missing libraries".
I have 'python3-pyqt5' installed but this doesn't appear to help.
During build CMake fails with:
...."Found unsuitable Qt version "5.15.1" from "../FreeCAD/Build FreeCAD/FreeCADLibs_12.4.3_x64_VC17/bin/qmake.exe", and
...."CMake Error at cMake/FreeCAD_Helpers/SetupQt.cmake:26 (message): .... Qt4 libraries not found."
unless I build with "Build_QT5" enabled. With Build_QT5 enabled CMake completes, and a Release Build with Visual Studio Community 2019 Version 16.8.5 is successful. But the Draft Workbench Snap Toolbar icons are blank.
I get the same result with earlier Libpacks, V12.1.2 onwards.
Is the python3-pyqt5 library missing from the Libpacks, or should I configure the build differently, please?
Any thoughts/advice/help would be much appreciated.
OS: Windows 10 Version 2004
Version: 0.19.23856 (Git)
Hash: 4db83a41ca5800a0238a3030c81e33950c3070a3
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
- FCsnap.png (152.11 KiB) Viewed 18617 times
Looks like the PCH must be rebuilt after the compiler update.
You should be able to Build > Clean Solution and then Build > Build Solution.
"fight the good fight"
I have created a new libpack with the fillet fix provided by Chris Hennes:
https://github.com/apeltauer/FreeCAD/re ... ack_12.5.1
Wow, that's awesome! Thank you!
apeltauer wrote: ↑Fri Feb 26, 2021 12:20 pm I have created a new libpack with the fillet fix provided by Chris Hennes:
Thank you @apeltauer. @Kunda1, I think this is a good milestone to use to mark those bugs in the tracker as resolved .
Test build available as the end of 0.19_pre
https://github.com/FreeCAD/FreeCAD/rele ... g/0.19_pre
The build should be 0.19 tag +1
https://github.com/FreeCAD/FreeCAD/comm ... eeCAD-0-19
