No silent windows deinstallation...
thomas.besser
Post by thomas.besser »
with Installer for version 0.16.6712 (https://github.com/FreeCAD/FreeCAD/rele ... _setup.exe) the old and solved problem (https://freecadweb.org/tracker/view.php?id=2056, https://forum.freecadweb.org/viewtopic.php?f=4&t=10532) reoccurs again.
Please make silent deinstallation working again.
Thomas
saxo
Re: No silent windows deinstallation...
Post by saxo »
Same here, please make a complete silent uninstall possible
Regards,
Sascha
sgrogan
Post by sgrogan »
saxo wrote: Mon Mar 26, 2018 4:26 pm Same here, please make a complete silent uninstall possible
Yes, I messed this up with the 0.16.6712 installer. I will try to fix this with the 0.17 installer. Sorry for the inconvenience.
"fight the good fight"
thomas.besser
That would be nice. Hanging around with 0.16.6706 since then and cannot upgrade.
Thomas
saxo
Post by saxo »
sgrogan wrote: Mon Mar 26, 2018 10:03 pm
Wonderful when its done i would add it to our software deployment tool.
Thanks and good luck.
Regards,
Sascha
thomas.besser
Which one do you use?
For OPSI it's done ;-)
https://opsi.wzb.eu/dfn_freecad_0.16.6706-1.opsi
FYI, I recently tested silent deinstallation with the latest NSIS script and it worked without modifying it. Maybe the old installers have been created with an outdated version. I haven't explicitly tested this.
So, when using an installer built with the latest script you should get the file Uninstall.exe inside the installation directory. Now when calling it as Uninstall.exe /S it silently removes all files from the disk.
thomas.besser
Sent you a PM. Did you get it? It's here only in 'Outbox' instead of 'Sent messages'!?
EDIT: ok that behavior is normal in phpBB (http://www.gammaspectacular.com/phpBB3/ ... c.php?t=62)
saxo
Post by saxo »
wmayer wrote: Tue Mar 27, 2018 8:02 am So, when using an installer built with the latest script you should get the file Uninstall.exe inside the installation directory. Now when calling it as Uninstall.exe /S it silently removes all files from the disk.
After uninstall.exe /S an message dialog appears and its asking if you really want to uninstall and that is not the expected behaviour - it should be removed without asking
Regards,
Sascha
thomas.besser wrote: Tue Mar 27, 2018 8:15 am Sent you a PM. Did you get it? It's here only in 'Outbox' instead of 'Sent messages'!?
Yes, I got it. I will reply later today...
