[0.17] Error: Initializing one or more of the Draft modules failed
NormandC
Post by NormandC »
Okay, weird stuff: all the Draft toolbars are gone in the latest Ubuntu daily build. :?
Report view reports errors:
Error: Initializing one or more of the Draft modules failed, Draft will not work as expected.
Unknown command 'Draft_Line'
Unknown command 'Draft_Wire'
Unknown command 'Draft_Circle'
Unknown command 'Draft_Arc'
Unknown command 'Draft_Ellipse'
Unknown command 'Draft_Polygon'
Unknown command 'Draft_Rectangle'
Unknown command 'Draft_Text'
Unknown command 'Draft_Dimension'
Unknown command 'Draft_BSpline'
Unknown command 'Draft_Point'
Unknown command 'Draft_ShapeString'
Unknown command 'Draft_Facebinder'
Unknown command 'Draft_BezCurve'
Unknown command 'Draft_Label'
Unknown command 'Draft_Move'
Unknown command 'Draft_Rotate'
Unknown command 'Draft_Offset'
Unknown command 'Draft_Trimex'
Unknown command 'Draft_Upgrade'
Unknown command 'Draft_Downgrade'
Unknown command 'Draft_Scale'
Unknown command 'Draft_Edit'
Unknown command 'Draft_WireToBSpline'
Unknown command 'Draft_AddPoint'
Unknown command 'Draft_DelPoint'
Unknown command 'Draft_Shape2DView'
Unknown command 'Draft_Draft2Sketch'
Unknown command 'Draft_Array'
Unknown command 'Draft_PathArray'
Unknown command 'Draft_Clone'
Unknown command 'Draft_Drawing'
Unknown command 'Draft_Mirror'
Unknown command 'Draft_Stretch'
Unknown command 'Draft_VisGroup'
Unknown command 'Draft_Heal'
Unknown command 'Draft_FlipDimension'
Unknown command 'Draft_ToggleConstructionMode'
Unknown command 'Draft_ToggleContinueMode'
Unknown command 'Draft_Slope'
Unknown command 'Draft_SetWorkingPlaneProxy'
Unknown command 'Draft_ApplyStyle'
Unknown command 'Draft_ToggleDisplayMode'
Unknown command 'Draft_AddToGroup'
Unknown command 'Draft_SelectGroup'
Unknown command 'Draft_SelectPlane'
Unknown command 'Draft_ShowSnapBar'
Unknown command 'Draft_ToggleGrid'
Unknown command 'Draft_AutoGroup'
Unknown command 'Draft_UndoLine'
Unknown command 'Draft_FinishLine'
Unknown command 'Draft_CloseLine'
Unknown command 'Draft_Snap_Lock'
Unknown command 'Draft_Snap_Midpoint'
Unknown command 'Draft_Snap_Perpendicular'
Unknown command 'Draft_Snap_Grid'
Unknown command 'Draft_Snap_Intersection'
Unknown command 'Draft_Snap_Parallel'
Unknown command 'Draft_Snap_Endpoint'
Unknown command 'Draft_Snap_Angle'
Unknown command 'Draft_Snap_Center'
Unknown command 'Draft_Snap_Extension'
Unknown command 'Draft_Snap_Near'
Unknown command 'Draft_Snap_Ortho'
Unknown command 'Draft_Snap_Special'
Unknown command 'Draft_Snap_Dimensions'
Unknown command 'Draft_Snap_WorkingPlane'
Draft workbench activated
I've been trying the following:
  • Rename ~/.FreeCAD folder to generate a fresh one
  • Delete ~/.config/FreeCAD/FreeCAD.conf
  • Restore original ~/.FreeCAD folder but delete user.cfg and system.cfg
I've been playing around these things because I want to salvage stuff I need in .FreeCAD (my own custom stylesheet, Mods).
At first one or more of the things I listed worked, but now I can't get it working again, even when deleting everything. :?
It started doing that with the daily build from 2 days ago, I just updated with the one from today, no success.
Any idea what's going on?!?
Thanks.
OS: Ubuntu 16.04.2 LTS
Version: 0.17.11424 (Git)
Build type: None
Hash: e7c7c07cdac6594c8519aca5775b21495ef8cdcb
Python version: 2.7.12
Qt version: 4.8.7
OCC version: 7.1.0
and
Version: 0.17.11432 (Git)
Build type: None
Hash: 0768ae99cfd6036601f66658f6e0f923de9af6f2
Qt version: 4.8.7
OCC version: 7.1.0
NormandC
Re: [0.17] Error: Initializing one or more of the Draft modules failed
Post by NormandC »
I went back to this version from June 16th, which works:
Version: 0.17.11310 (Git)
Build type: None
Hash: d28bae3f52b3e7cf959e8b9f7bcff264f95db191
Qt version: 4.8.7
OCC version: 7.1.0
I will test further and build from source.
NormandC
Post by NormandC »
Okay, I built from source, and Draft is still not initializing properly.
Could somebody else please confirm this?
Thanks!
Self-compiled:
Build type: Unknown
Qt version: 4.8.7
OCC version: 7.1.0
yorik
Post by yorik »
I don't see anything weird in Draft code... Could you try
import Draft
import DraftTools
in the python console to see if any error message comes?
NormandC
Post by NormandC »
>>> import Draft
>>> import DraftTools
  File "/home/normand/compilation/FreeCAD/freecad-build/Mod/Draft/DraftTools.py", line 43, in <module>
    from DraftGui import todo, QtCore, QtGui, translate, utf8_decode
  File "/home/normand/compilation/FreeCAD/freecad-build/Mod/Draft/DraftGui.py", line 2141, in <module>
    FreeCADGui.draftToolBar = DraftToolBar()
  File "/home/normand/compilation/FreeCAD/freecad-build/Mod/Draft/DraftGui.py", line 304, in __init__
    self.setupTray()
  File "/home/normand/compilation/FreeCAD/freecad-build/Mod/Draft/DraftGui.py", line 650, in setupTray
    self.wplabel.setToolTip(translate("draft", "Current working plane:")+self.wplabel.text())
UnicodeDecodeError: 'ascii' codec can't decode byte 0xc2 in position 22: ordinal not in range(128)
NormandC
Post by NormandC »
I just noticed your latest commit git commit 3ada141. Unfortunately it changes nothing.
Version: 0.17.11433 (Git)
Build type: Unknown
Hash: 3ada1416bad6518f3ee69bbcf7e11bbcbb2ff7ee
Qt version: 4.8.7
OCC version: 7.1.0
>>> import Draft
>>> import DraftTools
    self.setupTray()
NormandC
Post by NormandC »
Shot in the dark, I'm completely lost with this.
I found https://stackoverflow.com/questions/211 ... ecode-byte
Which made me try in FreeCAD's python console:
>>> import sys
>>> sys.getdefaultencoding()
'ascii'
I'm guessing it should return utf8?
Checked with both 0.16.6710 and freecad-daily built from git commit d28bae3, both return ascii.
NormandC
Post by NormandC »
Could this be related? git commit fe66e96
sgrogan
Post by sgrogan »
NormandC wrote: Sat Jun 24, 2017 7:21 pm Could somebody else please confirm this?
No problems here:
self-compiled
OS: Ubuntu 14.04.5 LTS
Build type: Unknown
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 7.1.0
or freecad-daily
Build type: None
Qt version: 4.8.6
OCC version: 7.1.0
"fight the good fight"
bejant
Post by bejant »
Thanks!
It is fine for me as well using
Word size of OS: 32-bit
Word size of FreeCAD: 32-bit
Version: 0.17.11379 (Git)
Build type: None
Hash: 654276c49d1b66cf3c2a5ec538629c6d9f77c489
Qt version: 4.8.7
OCC version: 7.1.0
and also after updating to the newest daily:
Build type: None
Qt version: 4.8.7
OCC version: 7.1.0
