Bug #2540: Crash on startup
issue #2540: Crash on startup
Please read the ticket thread starting from: http://freecadweb.org/tracker/view.php?id=2540#c7959
OS: "Gentoo Base System release 2.3"
Version: 0.17.9795 (Git)
Build type: Debug
Hash: d9dda3fa1d26915bef1508c4bc31f3a7ef270dfe
Python version: 2.7.12
Qt version: 4.8.6
Coin version: 3.1.3
OCC version: 6.9.0
OP says that:
If I comment out this line, it works.
Index: freecad-9999/src/Gui/Splashscreen.cpp
--- freecad-9999.orig/src/Gui/Splashscreen.cpp
+++ freecad-9999/src/Gui/Splashscreen.cpp
@@ -134,7 +134,7 @@ public:
                 return;
- splash->showMessage(msg.replace(QLatin1String("\n"), QString()), alignment, textColor);
+ //splash->showMessage(msg.replace(QLatin1String("\n"), QString()), alignment, textColor);
         QMutex mutex;
         QMutexLocker ml(&mutex);
         QWaitCondition().wait(&mutex, 50);
smellyfis
Re: Bug #2540: Crash on startup
Post by smellyfis »
I am having similar issues
attaching my gdb bt since i can't register for the bug tracker
freecad_0.16_bt_full.txt
(5.71 KiB) Downloaded 50 times
smellyfis wrote:I am having similar issues
@smellyfis can you please also post the Help > About FreeCAD > Copy to clipboard data ?
I added the BT here for more convenience:
Reading symbols from FreeCAD...(no debugging symbols found)...done.
(gdb) r
Starting program: /usr/bin/FreeCAD
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib64/libthread_db.so.1".
FreeCAD 0.16, Libs: 0.16RUnknown
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2015
              using visual class 4, id 63
              0x00007ffff5893748 in QWidgetPrivate::drawWidget(QPaintDevice*, QRegion const&, QPoint const&, int, QPainter*, QWidgetBackingStore*) () from /usr/lib64/qt4/libQtGui.so.4
              (gdb) bt full
#0  0x00007ffff5893748 in QWidgetPrivate::drawWidget(QPaintDevice*, QRegion const&, QPoint const&, int, QPainter*, QWidgetBackingStore*) () from /usr/lib64/qt4/libQtGui.so.4
              No symbol table info available.
#1  0x00007ffff5a639f2 in ?? () from /usr/lib64/qt4/libQtGui.so.4
#2  0x00007ffff5886250 in QWidgetPrivate::syncBackingStore() () from /usr/lib64/qt4/libQtGui.so.4
#3  0x00007ffff5899448 in QWidget::event(QEvent*) () from /usr/lib64/qt4/libQtGui.so.4
#4  0x00007ffff5ca0d32 in QSplashScreen::event(QEvent*) () from /usr/lib64/qt4/libQtGui.so.4
#5  0x00007ffff58415ac in QApplicationPrivate::notify_helper(QObject*, QEvent*) () from /usr/lib64/qt4/libQtGui.so.4
#6  0x00007ffff5848676 in QApplication::notify(QObject*, QEvent*) () from /usr/lib64/qt4/libQtGui.so.4
#7  0x00007ffff71cd385 in Gui::GUIApplication::notify(QObject*, QEvent*) () from /usr/lib64/libFreeCADGui.so
#8  0x00007ffff531611d in QCoreApplication::notifyInternal(QObject*, QEvent*) () from /usr/lib64/qt4/libQtCore.so.4
#9  0x00007ffff5a653c4 in ?? () from /usr/lib64/qt4/libQtGui.so.4
#10 0x00007ffff5888b45 in QWidget::repaint(QRect const&) () from /usr/lib64/qt4/libQtGui.so.4
#11 0x00007ffff5888ba3 in QWidget::repaint() () from /usr/lib64/qt4/libQtGui.so.4
#12 0x00007ffff5ca0589 in QSplashScreen::repaint() () from /usr/lib64/qt4/libQtGui.so.4
#13 0x00007ffff74561d4 in Gui::SplashObserver::Log(char const*) () from /usr/lib64/libFreeCADGui.so
#14 0x00007ffff67d2b55 in Base::ConsoleSingleton::NotifyLog(char const*) () from /usr/lib64/libFreeCADBase.so
#15 0x00007ffff67d2c5a in Base::ConsoleSingleton::Log(char const*, ...) () from /usr/lib64/libFreeCADBase.so
#16 0x00007ffff51f61f6 in qt_message_output(QtMsgType, char const*) () from /usr/lib64/qt4/libQtCore.so.4
#17 0x00007ffff343d45d in QGLWindowSurface::hijackWindow(QWidget*) () from /usr/lib64/qt4/libQtOpenGL.so.4
#18 0x00007ffff343ee53 in QGLWindowSurface::updateGeometry() () from /usr/lib64/qt4/libQtOpenGL.so.4
#19 0x00007ffff343fe38 in QGLWindowSurface::beginPaint(QRegion const&) () from /usr/lib64/qt4/libQtOpenGL.so.4
#20 0x00007ffff5a63778 in ?? () from /usr/lib64/qt4/libQtGui.so.4
#21 0x00007ffff5886250 in QWidgetPrivate::syncBackingStore() () from /usr/lib64/qt4/libQtGui.so.4
#22 0x00007ffff5899448 in QWidget::event(QEvent*) () from /usr/lib64/qt4/libQtGui.so.4
#23 0x00007ffff5ca0d32 in QSplashScreen::event(QEvent*) () from /usr/lib64/qt4/libQtGui.so.4
#24 0x00007ffff58415ac in QApplicationPrivate::notify_helper(QObject*, QEvent*) () from /usr/lib64/qt4/libQtGui.so.4
#25 0x00007ffff5848676 in QApplication::notify(QObject*, QEvent*) () from /usr/lib64/qt4/libQtGui.so.4
#26 0x00007ffff71cd385 in Gui::GUIApplication::notify(QObject*, QEvent*) () from /usr/lib64/libFreeCADGui.so
#27 0x00007ffff531611d in QCoreApplication::notifyInternal(QObject*, QEvent*) () from /usr/lib64/qt4/libQtCore.so.4
#28 0x00007ffff5a65414 in ?? () from /usr/lib64/qt4/libQtGui.so.4
#29 0x00007ffff5888b45 in QWidget::repaint(QRect const&) () from /usr/lib64/qt4/libQtGui.so.4
#30 0x00007ffff5888ba3 in QWidget::repaint() () from /usr/lib64/qt4/libQtGui.so.4
#31 0x00007ffff5ca0589 in QSplashScreen::repaint() () from /usr/lib64/qt4/libQtGui.so.4
#32 0x00007ffff74561d4 in Gui::SplashObserver::Log(char const*) () from /usr/lib64/libFreeCADGui.so
#33 0x00007ffff67d2b55 in Base::ConsoleSingleton::NotifyLog(char const*) () from /usr/lib64/libFreeCADBase.so
wmayer
Post by wmayer »
In your callstack this function appears:
So, this means Qt internally writes a log message or warning after the writing text to the splash screen. It would be interesting to know what this message is about. Can you start FreeCAD in a terminal, please? If there this message doesn't appear then start FreeCAD with the option "--write-log" and go to $HOME/.FreeCAD to open the file FreeCAD.log.
smellyfis
Post by smellyfis »
Here is my log:
FreeCAD.log
(7.63 KiB) Downloaded 42 times
I cannot even open FreeCAD to get to the help>about FreeCAD
I also I am having problem finding libGL.so so I have to start with LD_PRELOAD=/usr/lib64/opengl/nvidia/lib/libGL.so. Other wise I get the following
libGL error: No matching fbConfigs or visuals found
libGL error: failed to load driver: swrast
Segmentation fault
wmayer
Post by wmayer »
Thanks for the log file. When looking into it I found a suspicious line
hijackWindow() context created for Gui::SplashScreen
which apparently comes from Qt and is raised when trying to create a GL context. I wonder why Qt tries to that for a normal widget.
According to http://stackoverflow.com/questions/8793 ... reated-for you should pass
-graphicssystem=raster
on the command line when starting FreeCAD.
wmayer wrote:Thanks for the log file. When looking into it I found a suspicious line
OP writes in http://freecadweb.org/tracker/view.php?id=2540#c7977
Yep, my default graphics system was set to opengl. If I run FC with QT_GRAPHICSSYSTEM=raster it works flawlessly! That's why FC was not crashing on my other computer, because it was set to default there.
@wmayer should we do anything more about this ?
