(solved) crash with ifc import?
paullee
Re: (Workaround) crash with ifc import?
Post by paullee »
I see, thanks :)
Basically make an account in below link. Some guidelines are available.
Thanks helping :)
https://tracker.freecadweb.org/my_view_page.php
Bug submission guidelines
thomas-neemann
Post by thomas-neemann »
paullee wrote: Fri Jan 07, 2022 8:24 pm ...
Thanks helping :)
done
https://tracker.freecadweb.org/view.php?id=4820
thomas-neemann
if you prefer to have a stp file instead of dae. then this is possible with this
./IfcConvert --no-normals 923.ifc 923.stp
923.stp
(516.66 KiB) Downloaded 71 times
thomas-neemann
Thanks for the fix, it's working now
how can you change the status "new" in the tracer?
Version: 0.20.27078 (Git) AppImage
Branch: (HEAD detached at bcdd926)
Hash: bcdd926686f2245fe60baface1cce1ab3dff7a5b
Python version: 3.9.9
Qt version: 5.12.9
OCC version: 7.5.3
thomas-neemann wrote: Tue Feb 01, 2022 8:00 am how can you change the status "new" in the tracer?
The issue itself is not fixed, or is it?
thomas-neemann
chrisb wrote: Tue Feb 01, 2022 10:46 am
apparently another fix solved this problem, it works now
thomas-neemann wrote: Tue Feb 01, 2022 10:48 am apparently another fix solved this problem, it works now
Thanks, I will close the ticket.
