(solved) crash with ifc import?
thomas-neemann
Post by thomas-neemann »
what can you do to prevent the freecad crashes during import e.g. this ifc file?
923.ifc
(24.57 KiB) Downloaded 65 times
930.FCStd
(71.34 KiB) Downloaded 53 times
Version: 0.20.26720 (Git) AppImage
Branch: (HEAD detached at 7bca26e)
Hash: 7bca26e7c14d4d43374ff7e0c8582735b249cbfd
Python version: 3.9.9
Qt version: 5.12.9
OCC version: 7.5.3
edit
usbim.viewer+ can view it
Last edited by thomas-neemann on Tue Feb 01, 2022 8:01 am, edited 4 times in total.
thomas-neemann
Re: Workaround for crash with ifc import?
if you create a compound with upgrade or part compound, it works. in my opinion that is enough to take part in a bim process based on geometry without any attributes.
930-upgrade.ifc
(21.97 KiB) Downloaded 60 times
Syres
Re: [solved] Workaround for crash with ifc import?
Post by Syres »
thomas-neemann wrote: Tue Jan 04, 2022 8:31 am what can you do to prevent the freecad crashes during import e.g. this ifc file?
923.ifc
To the best of my knowledge I'm using the default IFC Import settings and using the build below, the original file imports error free:
OS: Windows 7 Version 6.1 (Build 7601: SP 1)
Version: 0.20.26858 (Git)
Hash: e209bc706d35121098f9bac779bc6b09c24ddd95
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
Tree:
thomas-neemann
Syres wrote: Tue Jan 04, 2022 9:32 am
thank you for your cooperation. I also tested it with 0.19-3 and 0.18. apparently it works better on windows than on linux.
Greetings Thomas
thomas-neemann
next problem (crash by import)
http://openifcmodel.cs.auckland.ac.nz/Model/Details/377
Qt version: 5.12.9
OCC version: 7.5.3
Version: 0.19.24366 (Git) AppImage
Branch: (HEAD detached at 0f9259c)
Hash: 0f9259cda103ae1824ac16c68ac9b4a0d54b05fc
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.3
paullee
Post by paullee »
thomas-neemann wrote: Tue Jan 04, 2022 8:31 am 923.ifc
Confirmed crash on below AppImages on Fedora and Settings :-
OS: Fedora 34 (Workstation Edition) (GNOME/gnome)
Version: 0.19.24367 (Git) AppImage
Branch: (HEAD detached at c403473)
Hash: c4034739c472bf07fab55ca8f9225a52d4b88cf5
Qt version: 5.12.9
OCC version: 7.5.3
Qt version: 5.12.9
OCC version: 7.5.3
Screenshot from 2022-01-08 03-10-49.png (101.25 KiB) Viewed 2919 times
paullee
Post by paullee »
Extract of log in AppImage 26306
Log: Init:      Initializing /home/paullee/Downloads/FreeCAD_weekly-builds-26306-Linux-Conda_glibc2.12-x86_64/squashfs-root/usr/Mod/Web... done
Msg: Opening '/home/paullee/Documents/Doc/00_ FreeCAD Test_ COPY/0_ FreeCAD__ Forum/FreeCAD_ thomas-neemann/923.ifc'... Msg: done.
Msg: Building types and relationships table...
Msg: done.
Msg: Parsing 13 BIM objects...
Log: Loading GUI of Part module... done
Msg: 1Msg:  Msg: /Msg:  Msg: 13Msg:  Msg: object #60Msg:  Msg: :Msg:  Msg: IfcWallMsg: Msg:  no layer foundMsg:  Msg: IfcWallMsg: Msg:  (arch)Msg: Err: Program received signal SIGSEGV, Segmentation fault.
Err: #0  /lib64/libc.so.6(+0x3d320) [0x7fb2b4d04320]
Err: #1  0x7fb27b6623f5 in Standard_Transient::DecrementRefCounter() const from /home/paullee/Downloads/FreeCAD_weekly-builds-26306-Linux-Conda_glibc2.12-x86_64/squashfs-root/usr/lib/./libTKernel.so.7+0x5
Err: #2  /home/paullee/Downloads/FreeCAD_weekly-builds-26306-Linux-Conda_glibc2.12-x86_64/squashfs-root/usr/lib/python3.9/site-packages/ifcopenshell/_ifcopenshell_wrapper.so(+0x23d5432) [0x7fb1df5e5432]
Err: #3  /home/paullee/Downloads/FreeCAD_weekly-builds-26306-Linux-Conda_glibc2.12-x86_64/squashfs-root/usr/lib/python3.9/site-packages/ifcopenshell/_ifcopenshell_wrapper.so(+0x23e6a25) [0x7fb1df5f6a25]
Err: #4  /home/paullee/Downloads/FreeCAD_weekly-builds-26306-Linux-Conda_glibc2.12-x86_64/squashfs-root/usr/lib/python3.9/site-packages/ifcopenshell/_ifcopenshell_wrapper.so(+0x23e6b01) [0x7fb1df5f6b01]
Err: #5  0x7fb1dff1d5e0 in vtable for NCollection_BaseMap from /home/paullee/Downloads/FreeCAD_weekly-builds-26306-Linux-Conda_glibc2.12-x86_64/squashfs-root/usr/lib/python3.9/site-packages/ifcopenshell/_ifcopenshell_wrapper.so+0x10
thomas-neemann
paullee wrote: Fri Jan 07, 2022 7:13 pm ..
thank you for testing
workaround:
works very quickly (in a few minutes)
linux-shell:
./IfcConvert --no-normals 1.ifc 1.dae
IfcOpenShell IfcConvert 0.6.0b0 (OCC 7.3.0)
Scanning file...
Done scanning file
Parsing input file took 6 seconds
Creating geometry...
Done creating geometry (16881 objects)
Log:
[Error] {2_uJNkuoDEcAk5Hec1nPUQ} Opening subtraction failed for 1 openings
#659652=IfcWallStandardCase('2_uJNkuoDEcAk5Hec1nPUQ',#41,'Basic Wall:_H-BW-1:2272912',$,'Basic Wall:_H-BW-1',#659615,#659650,'2272912')
Conversion took 3 minutes 30 seconds
paullee
Post by paullee »
thomas-neemann wrote: Fri Jan 07, 2022 8:00 pm workaround:
linux-shell:
Scanning file...
Done scanning file
Log:
Cool ! Did you compile the ifcopenshell ? Or some way to use the "built-in" in the AppImage?
Can you report it in the Mantis BugTracker ?
thomas-neemann
paullee wrote: Fri Jan 07, 2022 8:15 pm ...Did you compile the ifcopenshell ? Or some way to use the "built-in" in the AppImage?
i can't remember compiling it. i compile very little because i often have problems with it.
I think it's from here
http://ifcopenshell.org/ifcconvert
how do i report it in the bug tracer?
is there an instruction?
