My FreeCAD details:
OS: Ubuntu 20.04.3 LTS (ubuntu:GNOME/ubuntu)
Version: 0.20.
Branch: unknown
Hash: 8585149ab4ee0c165c5c443e84915741968d5624
Python version: 3.8.10
Qt version: 5.12.8
OCC version: 7.5.2
Concerning IfcOpenShell I've updated and compiled the v0.6.0 branch this morning.
When importing an IFC file, some elements are missing. In the report view, there is a possibly related message "failed to compute placement"
If I use https://view.ifcopenshell.org/ there are not missing elements.
Any thoughts?
Elements missing when importing IFC model with FreeCAD
- thomas-neemann
Re: Elements missing when importing IFC model with FreeCAD
if you need a quick solution you could import it into blender, export it as a dae and open it in freecadl_pereztato wrote: ↑Fri Dec 17, 2021 2:15 pm ....
When importing an IFC file, some elements are missing. ...
Thank you very much (and sorry for the late reply).
I'll try this solution.
Hi, there.
This works, but all the metadata are lost.
I've found some related questions (I don't know why I didn't find them before):
would you provide the file or would you provide a file which only has a few of this missing objects?
IfcOpenShel is not the newest in FreeCAD. You could try to use a newer version from IfcOpenBot or compile IfcOpenShell yourself.
Hi Bernd. Thanks for your reply.
The IFC file is not mine, so I can't share it here; I can send it by mail.
Concerning the IfcOpenShell library, I compile it myself (0.6.0 branch) from the sources in GitHub. If I type "locate libIfc" on my system, I get:
/home/luis/prg/build/IfcOpenShell/libIfcGeom.a
/home/luis/prg/build/IfcOpenShell/libIfcGeom_ifc2x3.a
/home/luis/prg/build/IfcOpenShell/libIfcGeom_ifc4.a
/home/luis/prg/build/IfcOpenShell/libIfcGeom_ifc4x1.a
/home/luis/prg/build/IfcOpenShell/libIfcGeom_ifc4x2.a
/home/luis/prg/build/IfcOpenShell/libIfcGeom_ifc4x3_rc1.a
/home/luis/prg/build/IfcOpenShell/libIfcGeom_ifc4x3_rc2.a
/home/luis/prg/build/IfcOpenShell/libIfcGeom_ifc4x3_rc3.a
/home/luis/prg/build/IfcOpenShell/libIfcGeom_ifc4x3_rc4.a
/home/luis/prg/build/IfcOpenShell/libIfcParse.a
/home/luis/prg/build/ifcplusplus/Release/libIfcPlusPlus.a
/usr/local/lib/libIfcGeom.a
/usr/local/lib/libIfcGeom_ifc2x3.a
/usr/local/lib/libIfcGeom_ifc4.a
/usr/local/lib/libIfcGeom_ifc4x1.a
/usr/local/lib/libIfcGeom_ifc4x2.a
/usr/local/lib/libIfcGeom_ifc4x3_rc1.a
/usr/local/lib/libIfcGeom_ifc4x3_rc2.a
/usr/local/lib/libIfcGeom_ifc4x3_rc3.a
/usr/local/lib/libIfcGeom_ifc4x3_rc4.a
/usr/local/lib/libIfcParse.a
/usr/local/lib/libIfcPlusPlus.a
So, if I'm not wrong, there are no other IfcOpenShell versions installed.
- thomas-neemann
as a quick transition solution you could convert it to a stp file.l_pereztato wrote: ↑Fri Dec 17, 2021 2:15 pm ...
When importing an IFC file, some elements are missing....
example:
https://forum.freecadweb.org/viewtopic. ... 67#p559867
download
http://ifcopenshell.org/ifcconvert
Thank you, Thomas. I'll try.
