Problems exporting IFC in FreeCAD 0.19
artyfex
Post by artyfex »
Hi everyone. I'm Emiliano, from Brazil. I'm new in the community and I'd like some help.
I have a Flathub install of FreeCAD 0.19 on my Linux Mint 20.2, and I cannot export .ifc files.
I receive the following traceback from FreeCAD python terminal:
>>> import ifcopenshell
  File "/app/lib/python3.8/site-packages/ifcopenshell/__init__.py", line 47, in <module>
    from . import ifcopenshell_wrapper
  File "/app/lib/python3.8/site-packages/shiboken2/files.dir/shibokensupport/__feature__.py", line 142, in _import
  File "/app/lib/python3.8/site-packages/ifcopenshell/ifcopenshell_wrapper.py", line 759, in <module>
    class FileDescription(HeaderEntity):
  File "/app/lib/python3.8/site-packages/ifcopenshell/ifcopenshell_wrapper.py", line 783, in FileDescription
    __swig_getmethods__["description"] = description
NameError: name '__swig_getmethods__' is not defined
During handling of the above exception, another exception occurred:
  File "/app/lib/python3.8/site-packages/ifcopenshell/__init__.py", line 55, in <module>
    raise ImportError("IfcOpenShell not built for '%s'" % python_distribution)
ImportError: IfcOpenShell not built for 'linux/64bit/python3.8'
The thing is: I have IfcOpenShell installed in my Anaconda directory: /home/emiliano/.anaconda3/lib/python3.8/site-packages/ifcopenshell and when I import ifcopenshell I don't get any traceback from the conda terminal.
I tried sys.path.append("/home/emiliano/.anaconda3/lib/python3.8/site-packages") in FreeCAD terminal, but the traceback persists and the path disappears after I restart FreeCAD.
Can anyone give me a hint of what I can do?
bernd
Re: Problems exporting IFC in FreeCAD 0.19
Post by bernd »
It seams your ifcopenshell in Anaconda is not compiled for python 3.8.
you can get the latest binaries from here: https://github.com/IfcOpenBot/IfcOpenSh ... its/master Just click on the newes comment available.
BTW: compiling ifcopenshell does work on most linux distribution right out of the box once the packages are installed.
Reason: fixed url
artyfex
Post by artyfex »
Thanks @bernd for your quick reply.
I was able to fix my problem with the following approach (just in case someone else needs it):
I uninstalled Freecad flathub from Linux Mint package manager and reinstalled it through conda terminal with the commands:
conda install -c conda-forge freecad
conda install -c conda-forge ifcopenshell
Now it works smoothly :D
bernd
Post by bernd »
Ahh, sure as they have the same Python version this works too.
Are you able to post the version you use? I do not know who maintains this build.
Would be interesting to know how old it is, or if it is a 0.19 release version.
AFAIK you could also use the FreeCAD App image. Ifcopenshell might be included there.
cheers bernd
paullee
Post by paullee »
I use AppImage on Fedora, seems Ifcopenshell included there.
artyfex
Post by artyfex »
These are the versions conda installed in my computer.
FreeCAD info:
OS: Linux Mint 20.2 (X-Cinnamon/cinnamon)
Version: 0.19.24291 (Git)
Branch: (HEAD detached at 0.19.2)
Python version: 3.9.2
Qt version: 5.12.9
OCC version: 7.5.1
IFC Open Shell info:
ifcopenshell v0.6.0 py38hb8a4352_3
To tell you the truth, I've never been an "experienced linux user" and I spent a couple years without using the OS, so I fell a bit confused with the way some packages are managed. Back then, apt-get seemed to solve most of my problems :lol:
bernd
Post by bernd »
Apart from FreeCAD and IfcOpenShell which I do compile myself, apt-get still solves 99% of my problems.
bernd
Post by bernd »
Ahh I forgot... For Some python packages I have to use pip, because Debian stable onl has old versions...
