BIM - IfcOpenShell importer problems
maker
Post by maker »
Hi Community,
OS: openSUSE Leap 15.2 (KDE//usr/share/xsessions/default)
Version: 0.20.Unknown
Python version: 3.6.10
Qt version: 5.12.7
OCC version: 7.5.1
looking for a solution to import some provided FreeCAD *.ifc files into FC, I had a longer net research to find a solution for my used OS because the IfcOpenShell version [here: IfcOpenShell-python for python 3.6 64bit Linux] provided at http://ifcopenshell.org/python did not work. :!:
Luckily I have ended up with IfcOpenShell which has to be provided in the openSUSE Leap 15.2 package version, which I've finally found in as an non-official openSUSE build repo.
I've carried out testing FreeCAD BIM WB with the installed IfcOpenShell.rpm against the online
viewer https://view.ifcopenshell.org/ with a total of 5 *.ifc files.
Unfortunately 2 of these *.ifc files show the following error message in the FreeCAD report
panel:
12:38:31  Traceback (most recent call last):
  File "/usr/lib64/FreeCAD/Mod/Arch/importIFC.py", line 211, in open
    doc = insert(filename, doc.Name, skip, only, root)
  File "/usr/lib64/FreeCAD/Mod/Arch/importIFC.py", line 350, in insert
    mattable = importIFCHelper.buildRelMattable(ifcfile)
  File "/usr/lib64/FreeCAD/Mod/Arch/importIFCHelper.py", line 244, in buildRelMattable
    for o in r.RelatedObjects:
<class 'TypeError'>: 'NoneType' object is not iterable
--> Results:
1) file does not open in FreeCAD
2) file opens correctly without error message on https://view.ifcopenshell.org/
Maybe view.ifcopenshell.org is using IfcOpenShell in the back-end, so it could be explained that the online viewer works fine.
I don't have an detailed idea how the BIM workbench cooperates with IfcOpenShell during *.ifc file import, apparently there is a problem in Python code, as the error message above shows.
Does anyone have an idea what is running wrong in Ifc importer python script files:
importIFC.py
importIFCHelper.py
and to what this is related to?
...for the sake of completeness I would like to mention while all *.ifc files are opened online on https://view.ifcopenshell.org/
properly without any problems, 3 other *.ifc files show some different minor error messages in the FreeCAD report
panel:
13:13:02  failed to compute placement
13:13:12  failed to compute placement
could not create roof
13:29:03  Failed to rebuild a valid solid for object  Component039
13:29:03  Failed to rebuild a valid solid for object  Component040
object color != material color for object:  752457
13:29:03      material color is used (most software uses shape color)
although it looks quite complete in FC's 3D view...
maker
Re: BIM - IfcOpenShell importer problems
Post by maker »
a close look in the installed and nominated file /usr/lib64/FreeCAD/Mod/Arch/importIFC.py
produces in line 211
in line 350
and a close look in the installed and nominated file /usr/lib64/FreeCAD/Mod/Arch/importIFCHelper.py
and here in line 244
Does anyone have an idea what is running wrong in the 2 Ifc importer python script files?? :geek:
Roy_043
Post by Roy_043 »
Try:
def buildRelMattable(ifcfile):
    """Build the mattable relation table."""
    mattable = {}  # { objid:matid }
    for r in ifcfile.by_type("IfcRelAssociatesMaterial"):
        if r.RelatedObjects:
                if r.RelatingMaterial.is_a("IfcMaterial"):
                    mattable[o.id()] = r.RelatingMaterial.id()
                elif r.RelatingMaterial.is_a("IfcMaterialLayer"):
                    mattable[o.id()] = r.RelatingMaterial.Material.id()
                elif r.RelatingMaterial.is_a("IfcMaterialLayerSet"):
                    mattable[o.id()] = r.RelatingMaterial.MaterialLayers[0].Material.id()
                elif r.RelatingMaterial.is_a("IfcMaterialLayerSetUsage"):
                    mattable[o.id()] = r.RelatingMaterial.ForLayerSet.MaterialLayers[0].Material.id()
    return mattable
maker
Post by maker »
@Roy_043
Thank you so much! YOUR analysis and input with the additional line in the importIfcHelper.py file
was apparently the solution!!
I copied your code-snippet line and inserted it in importIfcHelper.py file. The following test run already showed after a few seconds that the "importing behaviour" of the two .ifc files was completely different. The importing process started running...
And finally after approximately 1128 seconds each model were imported with minor errors, such as:
Unable to create a roof
although the models had both roofs...
How can it be arranged for the FC community, that the additional python code line will be added to importIfcHelper.py?
bernd
Post by bernd »
Moult
Post by Moult »
Can I perhaps make a suggestion here that the line of code added may be a symptom covering a more fundamental problem. I would recommend reverting the commit and finding the fundamental problem.
The cardinality of RelatedObjects in IfcRelAssociatesMaterial is S[1:?] - this means that it must always exist - the "if" statement should never be required. This suggests that the originator of the IFC files created malformed IFCs. If FreeCAD created the IFC files to begin with, then this is a great opportunity to find the issue within FreeCAD's exporter and fix it there. Over time, I believe this "stricter" strategy can lead to much more robust IFC handling in IFC.
maker
Post by maker »
I would not retract the commit, as long as there is no better solution for the undoubtedly existing problem.
It is suspected that we are only curing the symptom here and not the problem.
Moult wrote: Tue May 18, 2021 11:12 pm ...]
In in my particular case, the files provided were created in autodesk Revit and then converted to .ifc files.
A sample .log file of conversion process shows this content:
* WriteStepFile diagnostics.
* Date:                           Tue May 11 19:46:36 2021
* Produced by:                    The EXPRESS Data Manager Version 5.02.0100.07 : 28 Aug 2013
* Module:                         EDMstepFileFactory/EDMstandAlone
* Host:                           LAPTOP-anon
* Database:                       C:\Users\name\AppData\Local\Temp\a3651c51-c265-48d6-a197-195fdcd9102f\df0e3080-7a8b-4f8d-8216-b24c4cb65adc\ifc
* Database version:               5507
* Database creation date:         Tue May 11 19:44:53 2021
* Model:                          DataRepository.ifc
* Model creation date:            Tue May 11 19:44:53 2021
* Header model:                   DataRepository.ifc_HeaderModel
* Header model creation date:     Tue May 11 19:44:53 2021
* Step file:                      Filename - Lph 2.ifc
* EDMuser:                        sdai-user
* EDMgroup:                       sdai-group
* License ID and type:            5605 : Permanent license. Expiry date:
* EDMstepFileFactory options:     020000
Operation terminated successfully.
Nevertheless I agree with you. It is always better to find the root cause of a problem, than curing the symptom. I needed a quick solution for my problem, experience shows that solving the root cause takes usually unfortunately much more time...
bernd
Post by bernd »
We should not support Autodesk in providing corrupted ifc. I am with you moult.
Nerveless as a user I do know the problem. One has a dead line an the customer does not care if Autodesk does provide corrupted ifc. The custumer just would like to have to be delivered his data or drawings in time. If delivery will not be in time, big problems will arise ... I am with you too maker.
IMHO we should not read the file in standard mode and tell the user the file is corrupt. But we should allow him due to a preference to read the file anyway. This preference could even be hidden. Means not on the official preference gui but on the preference editor.
Arch is not my may play ground, but I may have a look at this anyway.
cheers bernd
yorik
Post by yorik »
It is also my philosophy to be tolerant with bad IFC files... Of course Autodesk issuing poor files is really shameful and we have definitely no interest in being tolerant with Autodesk, but I can very well imagine another app that is not well versed in IFC that didn't interpret correctly the specs, and having only Autodesk files as examples to work with. It wouldn't be entirely their fault IMHO.
In this case it doesn't really harm to perform that test, and after all only turns FreeCAD more resistant.
