Cannot Export to IFC with 0.19_pre
romainbonjour
Post by romainbonjour »
I have an error message when trying to export my Model to IFC (file / export / IFC). In the report view, I get:
File "<string>", line 4, in <module>
File "C:\Users\RBr\FreeCAD_0.19\Mod\Arch\exportIFC.py", line 264, in export
b = Draft.getCloneBase(o,strict=True)
<class 'AttributeError'>: module 'Draft' has no attribute 'getCloneBase'
In order to check if I had a problem with my model, I have also tried with “house.FCStd” from Yorik's Tutorial. The log from above is from this trial.
Hope you can help!
Thanks in advance,
Romain
PS:I am new to FreeCAD, and I love it. I would probably not use the other CADs I have... Thanks everyone.
--- some info about my config.
When I put “import ifcopenshell” and “from “ifcopenshell import geom”, I do not get errors. Seems fine.
Freecad downloaded from https://github.com/FreeCAD/FreeCAD/rele ... g/0.19_pre
ifcopenshell was « updated » (I have replaced python files) from http://ifcopenshell.org/python . but this does not help.
Version: 0.19.20943 (Git)
Hash: ceb23799c76df3ebfa7be4b9fe83bb62de60bc6c
Python version: 3.8.2
fc_tofu
Re: Cannot Export to IFC with 0.19_pre
Post by fc_tofu »
I confirm.
Locale: Chinese/China (zh_CN)
vocx
Post by vocx »
romainbonjour wrote: Wed May 13, 2020 2:13 pm ...
You need to update your version. The problem was corrected in git commit 64619a615, 0.19.21031.
romainbonjour
Hum, meaning I have to compile from Source... I will try that!
Thanks
bernd
Post by bernd »
romainbonjour wrote: Thu May 14, 2020 9:30 am Hum, meaning I have to compile from Source... I will try that!
Thanks
or use conda build which is on 0.19.21049 or wait a few days.
romainbonjour
Thanks a lot!
I lost 1 day trying to compile, while I just needed to put 3-4 lines in my Conda env...
bernd
Post by bernd »
the dev version is on 0.19.21068 means it should word with it
fc_tofu
Post by fc_tofu »
bernd wrote: Fri May 15, 2020 7:48 am the dev version is on 0.19.21068 means it should word with it
Thank you.
I tested in latest build, with "house.FCStd" from @yorik.
At this time export to .ifc succeed without error msg. But when importing-back, partial model is lost. Prompt msg in Report View.
Width & OverrideWidth & base.getWidths() should not be all 0 or None or [] empty list
Error: Invalid base object
Failed to rebuild a valid solid for object  Component
Failed to rebuild a valid solid for object  Component001
Failed to rebuild a valid solid for object  Structure
Failed to rebuild a valid solid for object  Structure001
Failed to rebuild a valid solid for object  Structure002
Failed to rebuild a valid solid for object  Structure003
Failed to rebuild a valid solid for object  Structure004
Failed to rebuild a valid solid for object  Structure005
Failed to rebuild a valid solid for object  Wall
Failed to rebuild a valid solid for object  Window
Finished importing.
Version: 0.19.21049 (Git)
Hash: 9c27f1078e5ec516fe882aac1a27f5c6c6174554
test.ifc
(35.37 KiB) Downloaded 77 times
Syres
Post by Syres »
I get a much more complete but not perfect import (both export and import done with 0.19.21068):
failed to compute placement
Loading Drawing module... done
Finished importing.
OS: Windows 7 SP 1 (6.1)
Version: 0.19.21068 (Git)
Hash: 92fe9adebbff910c5a10d6230785a6b58935b677
Python version: 3.6.8
Qt version: 5.12.1
House.ifc
(21.38 KiB) Downloaded 87 times
l_pereztato
Post by l_pereztato »
I have the same problem when importing House.ifc
OS: Ubuntu 20.04.3 LTS (ubuntu:GNOME/ubuntu)
Version: 0.20.
Branch: unknown
Hash: 472c09cd09a02209e1179d25e0a727db5d374ebb
Python version: 3.8.10
Qt version: 5.12.8
OCC version: 7.5.2
