[ Solved ][ Ticket #4141: Multi-solid walls are not correctly exported to IFC ] Brep IFC export should be ON by default?
paullee
Re: [ Solved ][ Ticket #4141: Multi-solid walls are not correctly exported to IFC ] Brep IFC export should be ON by defa
Post by paullee »
Ok, I marked in the mantis, hope it is done correctly :)
paullee wrote: Mon Dec 09, 2019 5:01 pm Ok, I marked in the mantis, hope it is done correctly :)
Yes, sir. You most certainly did it correctly. ;)
bernd
Post by bernd »
How about the export option? As far as I know it is still set to False by default. https://github.com/FreeCAD/FreeCAD/blob ... FC.py#L151 Means this is not solved ATM.
