IFC files from structural engineering software CSI ETABS
- ebrahim raeyat
@yorik Thanks so much. I have been imported CSI ETABS ifc file into FreeCAD with succeed:
It seems all aspect ratios of lengths is correct, but in properties panel all height dimentions set to 1000 mm and width to 100 mm.
thanks so much.
OS: Manjaro Linux
Version: 0.18.15303 (Git)
Hash: 6199c95fd71eacb9cc168426e55254aa79a42034
Python version: 3.6.7
Qt version: 5.6.2
thanks so much.
OS: Manjaro Linux
Qt version: 5.6.2
Re: BIM module development / enhancement
Cool. The file you exported from CSI ETABS is a Architectural View IFC. This ifc has volumes.
It seams CSI ETABS ist also able to export an structural analysis view ifc. Such an ifc has only edges and faces, means you export the structural geometry to ifc. (your picture one). FreeCAD can also impoort such an ifc if you activate the import in preferences.
- ebrahim raeyat
Thanks @bernd. yes it has structural layer for ifc:
but when i select that, nothing imported and this error appeared:
it also can export to IGES and STEP formats, but none of them work in freecad:
File "/home/ebi/Applications/squashfs-root/usr/Mod/Arch/importIFC.py", line 446, in insert
additions.setdefault(r.RelatingStructure.id(),[]).extend([e.id() for e in r.RelatedElements])
File "/home/ebi/Applications/squashfs-root/usr/Mod/ifcopenshell/entity_instance.py", line 63, in __getattr__
self.wrapped_data.get_argument(self.wrapped_data.get_argument_index(name)))
File "/home/ebi/Applications/squashfs-root/usr/Mod/ifcopenshell/ifcopenshell_wrapper.py", line 1960, in get_argument
return _ifcopenshell_wrapper.entity_instance_get_argument(self, *args)
<class 'RuntimeError'>: Token $ at 266018 invalid instance name
<class 'RuntimeError'>: FreeCAD exception thrown ()
wow cool, would you provide a simple file which creates the error? With a file I could tackle down the problem.
step and iges should work in FreeCAD too, but we shoulx go step by step, means IFC first. I may move this in a separate topic.
bernd
bernd
- ebrahim raeyat
yes, this is my file:
Re: IFC files from structural engineering software CSI ETABS
I get ...
with my rare geometry importer I get ...
I will have a look ...
Opening C:/Users/BHA/Desktop/struc.ifc ...done.
Building relationships table...Traceback (most recent call last):
File "C:\0_BHA_privat\progr\FreeCAD_0.18.xxxxx_x64_dev_win\Mod\Arch\importIFC.py", line 446, in insert
File "C:\0_BHA_privat\progr\FreeCAD_0.18.xxxxx_x64_dev_win\bin\lib\site-packages\ifcopenshell\__init__.py", line 50, in __getattr__
return entity_instance.wrap_value(self.wrapped_data.get_argument(self.wrapped_data.get_argument_index(name)))
File "C:\0_BHA_privat\progr\FreeCAD_0.18.xxxxx_x64_dev_win\bin\lib\site-packages\ifcopenshell\ifcopenshell_wrapper.py", line 1340, in get_argument
<type 'exceptions.RuntimeError'>: Token is not an integer or identifier
That's interesting. To create the arch model, etabs apparently just "extrudes" the analytic lines. You can see that objects are not well joined. We could do a far better job in freecad...
All Arch structure objects (columns, beams, slabs...) have a Nodes property which is a sequence of 3D vectors, that can represent a line or polyline. If the Role property of the object is set to "Slab", then if there are at least 3 points, it represents a face. (I'm thinking this ability should be separated in a separate property). The position of these nodes is calculated automatically taking the central fiber of the element, but it can also be edited manually, giving total control.
I never pushed these concepts further than that, but I think everything is there to have a good workflow already. One of these days we need to try to model an example building, which is exportable as both a coherent arch and structural IFC model... I haven't looked much at how one can "bind" a structural line and an arch object in IFC (ie. inform that they relate to the same object)
Also, being able to import an arch ifc, then a struct ifc of the same model, and have both "magically" reassembled would be kick-ass!
Oh yes we should and AFAIK it is not possible but I may be wrong. It would be cool if it would be possible !yorik wrote: ↑Fri Dec 07, 2018 12:39 pm One of these days we need to try to model an example building, which is exportable as both a coherent arch and structural IFC model... I haven't looked much at how one can "bind" a structural line and an arch object in IFC (ie. inform that they relate to the same object)
YEAH !
with a hack I was able to import the struct file. See attached screen. ETABS generates some rubbish IFC. In an strutural analysis model of an engineer in any case the members are connected. But they are not !!! Have a look at the picture no column is connected to the slab! Is there some preference in ETAB to connect the columns to the slab for the exported IFC?
Bernd
Bernd
- screen.jpg (296.12 KiB) Viewed 8544 times
