Very Thanks. It seems also beams not connected to the slab. it seems it not draw center to center of any column or beam at all.
etabs don't have any further options for this.
Thanks. Of course. but i have some question:
When an arch structure is based on a profile shape, Length and Width properties are not used. We should of course fix that at some point (set them automatically from the profile)...ebrahim raeyat wrote: ↑Sat Dec 08, 2018 8:36 pm 1- all length seems set to default in properties panel and when i change those, nothing happens in 3D view.
Thanks @yorik.
#512=IFCSTRUCTURALLOADSINGLEFORCE($,$,$,-8.0000000E+003,$,$,$);
#513=IFCSTRUCTURALLOADSINGLEFORCE($,$,$,-2.3000000E+003,$,$,$);
Thanks @bernd. I also very interesting in this new field area. BIM model. if you plane to do something I can intercommunicate.
Thanks. Etabs has a bug for about 5 years and many engineers contact with them, but still that bug is present in Etabs 2017!! I have been write a program that correct that bug and further options and it uses frequently in iran. I think XCFEM is the solution!bernd wrote: ↑Wed Dec 12, 2018 7:05 am great i'll let you know as soon as I start somthing in this regard.
BTW: It would be not a bad idea to get in contact with support of ETABS because of their rubbisch structural ifc. They are not usable at all. The members need to be connected to use the data in another software. All other structural engineering software I know do connect the members in structural analysis view export.
