Material improvements
A forum to discuss the implementation of a good Materials system in FreeCAD
ian.rees
Re: Material improvements
Post by ian.rees »
Apologies for the delay - I've rebased Eivind's work on to the latest master at https://github.com/ianrrees/FreeCAD_tin ... al2-rebase . Haven't been able to compile it yet, as my machine is only setup for building against Python 3 at the moment, which wasn't supported by the old branch.
ian.rees
Post by ian.rees »
OK, I've got a compile (pushed a few fixes to my branch), but am running in to a crash on startup, which seems to relate to initialising Python types. I'm really rusty in this area, and can't see an easy solution:
0x00007ffff54eab38 in PyUnicode_InternInPlace () from /usr/lib/x86_64-linux-gnu/libpython3.6m.so.1.0
(gdb) bt
#0  0x00007ffff54eab38 in PyUnicode_InternInPlace () from /usr/lib/x86_64-linux-gnu/libpython3.6m.so.1.0
#1  0x00007ffff54eac0d in PyUnicode_InternFromString () from /usr/lib/x86_64-linux-gnu/libpython3.6m.so.1.0
#2  0x00007ffff5595545 in PyType_Ready () from /usr/lib/x86_64-linux-gnu/libpython3.6m.so.1.0
#3  0x00007ffff5597408 in PyType_Ready () from /usr/lib/x86_64-linux-gnu/libpython3.6m.so.1.0
#4  0x00007ffff5b0fac2 in Py::PythonType::readyType (this=0x5555557b60f0)
    at /home/irees/Projects/freecad-code/src/CXX/Python3/cxx_extensions.cxx:283
#5  0x00007ffff64866e3 in Py::SolidMaterialArray::init_type ()
    at /home/irees/Projects/freecad-code/src/App/PropertyPartMaterial.cpp:321
#6  0x00007ffff64860f4 in Py::PropertyPartMaterial::init_type ()
    at /home/irees/Projects/freecad-code/src/App/PropertyPartMaterial.cpp:423
#7  0x00007ffff64d4615 in App::Application::initTypes ()
    at /home/irees/Projects/freecad-code/src/App/Application.cpp:1359
#8  0x00007ffff64d4421 in App::Application::init (argc=1, argv=0x7fffffffdbe8)
    at /home/irees/Projects/freecad-code/src/App/Application.cpp:1253
#9  0x000055555555c38e in main (argc=1, argv=0x7fffffffdbe8)
    at /home/irees/Projects/freecad-code/src/Main/MainGui.cpp:192
bernd
Post by bernd »
Great :D compiles and starts for me on Python2 . It even rebases on the latest commits from master
OS: Debian GNU/Linux 9.5 (stretch)
Version: 0.18.14805 (Git)
Build type: Unknown
Branch: materialian2
Hash: e16950459ae4e9c8e9ffd3852f8ccbe017443d01
Python version: 2.7.13
Qt version: 4.8.7
OCC version: 7.0.0
first find ... it is not possible to load a saved file. Not one saved with master not one saved with this branch.
bernd
Post by bernd »
It still rebases on master https://github.com/berndhahnebach/FreeC ... aterialian
but still the problems resist ...
bernd
Post by bernd »
https://github.com/berndhahnebach/FreeC ... rialeivind
still rebases, but not the material editor ui, but this is no that important. C++ code is still not finished. It would be a pitty if this development would be for trash eventually.
eivindkvedalen wrote: ping
eivindkvedalen
Post by eivindkvedalen »
bernd wrote: Wed Feb 27, 2019 5:17 pm https://github.com/berndhahnebach/FreeC ... rialeivind
Rebased on current master: https://github.com/eivindkv/FreeCAD/tree/Material2
It compiles, and it didn't crash when I opened a file :)
Eivind
bernd
Post by bernd »
Great! it is compiling ... Seams yor are still on Python2 At the moment I switched back to Py2 too because I had some compile error on Py3. I well report back.
bernd
Post by bernd »
Just a quote from eivind an ealier post to know what is this branch about:
eivindkvedalen wrote: Sun Aug 21, 2016 8:19 am Things more or less done:
- Added a MaterialDatabase class. This is the collection of various sources described below. Material queries happens from this database.
- Added a DefaultMaterialSource class. This source is read-only and contains the original pre-defined materials that could be selected in FreeCAD. It also contains a DEFAULT material, that all other materials can inherit from, to ensure that visual properties are defined.
- Added a DocumentMaterialSource class. Per-document materials are stored here. If visualization materials are changed, a copy is stored here.
- Added a FileMaterialSource class. FCMat materials cards are provided by this source. Multiple sources may be added (system/user).
- Added a PropertyPartMaterial class. This class and its helper classes encapsulates materials for solids and surfaces.
- Added a PropertyPartMaterial member Material to Part::Feature, along with its Shape.
I've been focusing on the data structure part now; almost nothing is done on the Gui part, except propagating material colors from the Material property to the view provider, so the colors of the parts change.
I have also added a Python interface (this is what I actually use for testing), and a typical use-case could be:
App.ActiveDocument.Box.Material.setSolidMaterial(0, "PLA");
This will assign the PLA material to solid 0 of Box. Properties can then be queried, e.g
App.ActiveDocument.Box.Material.Solid[0].YoungsModulus
Surface materials are accessed as e.g
App.ActiveDocument.Box.Material.Solid[0].setSurfaceMaterial(0, "GOLD")
(provided that Solid[0] has been set first).
The material databases are accessed either at
App.getMaterialDatabase()
or
doc.MaterialDatabase
(ideally they should have the same syntax; something for later). The material database in App is the application-wide database, so adding/removing/editing materials should be possible to do without an open document. The material database in the document links to the application-wide one, but also provides a private material source for materials specific for the document.
The file-based materials are supposed to be in either
getResourceDir() + "/Mod/Material/StandardMaterial"
or
getUserAppDataDir() + "Materials"
bernd
Post by bernd »
with Python2 and Qt5 I am able to compile this branch. But as soon as an object which has a Shape property is created FreeCAD crashes. Files with meshes or for example an FEM file without the shape saves and reopens fine.
OS: Debian GNU/Linux buster/sid (KDE//usr/share/xsessions/plasma)
Version: 0.19.16369 (Git)
Build type: Unknown
Branch: materialeivind
Hash: 159b004261e6fc932af376978710911aee26fc4e
Python version: 2.7.16rc1
Qt version: 5.11.3
eivindkvedalen
bernd wrote: Tue Apr 02, 2019 5:16 pm with Python2 and Qt5 I am able to compile this branch. But as soon as an object which has a Shape property is created FreeCAD crashes. Files with meshes or for example an FEM file without the shape saves and reopens fine.
I discovered that as well, and I'm looking into it now...
Eivind
