CfdOf Translating / Moving object workflow
Moderator: oliveroxtoby
I've tried to set up Transient analysis using dynamic mesh interface refinement, using a very basic model (attached) but I must be doing something wrong. I've also tried to follow several tutorials on translating / rotating objects (propeller example) but cannot figure out how to make that work in my case.
- Moving object
- Translating Object.png (309.72 KiB) Viewed 1254 times
- Moving object test.FCStd
- Sample model
- (27.18 KiB) Downloaded 36 times
Reason: Damage limitation after I edited this post in error, intending to reply.
- oliveroxtoby
Re: CfdOf Translating / Moving object workflow
@chrisv-nz my humble apologies, I accidentally edited (and truncated) your post above instead of replying to it...and I can't seem to find a way to undo the edit. Sorry about that!! My reply was meant to be:chrisv-nz wrote: ↑Fri Oct 07, 2022 10:48 pm I've tried to set up Transient analysis using dynamic mesh interface refinement, using a very basic model (attached) but I must be doing something wrong. I've also tried to follow several tutorials on translating / rotating objects (propeller example) but cannot figure out how to make that work in my case.
Unfortunately there is no support for moving mesh in CfdOF at the moment. The dynamic mesh refinement is for adaptive refinement of the interface in multiphase cases.
Hi
welcome
try:
select the object to move and run the macro
Macro_D_Un_Jour_Move_Object_To_Distance_In_A_Defined_Time
with this configuration i obtain:
14:43:50 ________________
14:43:50 Real Time elapsed : 00:00:9.937
14:43:50 timeTrajet asked : 10.0 secondes
14:43:50 lengthTrajet : 30000.0 mm
14:43:50 timeBetween_2_Step : 0.0 secondes
14:43:50 number of step : 1240
14:43:50 distance by 2 step : 24.193548387096776 mm
14:43:50 axis : 1 (0 = x, 1 = y, other = z)
mario
welcome
try:
##Macro_D_Un_Jour_Move_Object_To_Distance_In_A_Defined_Time
##09/10/2022
##Mario52
##https://forum.freecadweb.org/viewtopic.php?f=37&t=72433
import FreeCAD, FreeCADGui
import time
App = FreeCAD
Gui = FreeCADGui
####Configuration Begin
timeTrajet = 10.0 # secondes
lengthTrajet = 30000.0 # mm
timeBetween_2_Step = 0.0 # default=0.0 # secondes # precision depend : machine, memory, loop, code ...
# if timeBetween_2_Step is used the object is moved step by step
loopMultiply = 124 # default=10 (or other) if timeBetween_2_Step is used
# if timeBetween_2_Step = 0 search the good number of loop progressif
direction = 1 # 0 = "x" , 1 = "y" , other = "z"
####Configuration End
try:
sel = Gui.Selection.getSelection()[0] # select the object to move
#FreeCADGui.Selection.getSelectionEx()[0].SubObjects[0]
stepBySecond = (lengthTrajet / timeTrajet) # number of step by second
##### begin measure the time elapsed for a recompute "chrisb"
timeFn = time.perf_counter # measure real time
startTime = timeFn()
if loopMultiply == 0: loopMultiply = 1.0
try:
for i in range(int(timeTrajet*loopMultiply)): # multiply by 10 for 0.1 second
if direction == 0: # x
sel.Placement.Base.x = sel.Placement.Base.x + (stepBySecond/loopMultiply) # axis x
elif direction == 1: # y
sel.Placement.Base.y = sel.Placement.Base.y + (stepBySecond/loopMultiply) # axis y
else: # z
sel.Placement.Base.z = sel.Placement.Base.z + (stepBySecond/loopMultiply) # axis z
time.sleep(timeBetween_2_Step)
Gui.updateGui() # rafraichi lecran
#print(i," ",sel.Placement.Base.y)
except Exception:
print("Not good configuration")
##### end measure the time elapsed for a recompute "chrisb"
endTime = timeFn()
elapsed = (endTime - startTime)
print("________________")
print('Real Time elapsed : {:02d}:{:02d}:{:05.3f}'.format(int(elapsed) // 3600, (int(elapsed) % 3600 // 60), elapsed % 60))
print("timeTrajet asked : ", timeTrajet, " secondes")
print("lengthTrajet : ", lengthTrajet, " mm")
print("timeBetween_2_Step : ", timeBetween_2_Step, " secondes")
print("number of step : ", int(timeTrajet*loopMultiply))
print("distance by 2 step : ", stepBySecond/loopMultiply, " mm")
print("axis : ", direction, "(0 = x, 1 = y, other = z)")
except Exception:
print("Select one object")
mario
