Suggestion: Ask for confirmation before overwriting case files
Moderator: oliveroxtoby
ReneSci
Post by ReneSci »
When the user (by accident) press the "Write" or the "Run" button, the case files are immediately written or the solvers start immediately - and overwrites the case and/or the solver results files.
2022-09-14 13_38_58-FreeCAD 0.20.1.png (9.96 KiB) Viewed 810 times
This could be quite pity if these files contains the results of many hours of calculations which would then be lost.
Maybe the user just what to view the results again (by pressing ParaView)
Could it be an idea to ask for a "Overwrite files" confirmation to make the user "think" once more.
Eventually suggesting another path for the new files ?
Version: 0.20.1.29410 (Git)
Branch: releases/FreeCAD-0-20
Locale: Danish/Denmark (da_DK)
  * A2plus 0.4.59
  * ArchTextures
  * Assembly4 0.12.4
  * CfdOF 1.17.9
  * Defeaturing 1.2.0
  * Dracula 0.0.2
  * ExtremeProDark 1.0.4
  * IconThemes
  * lattice2 1.0.0
  * Manipulator 1.4.9
  * MeshRemodel 1.8919.0
  * parts_library
  * Plot 2022.4.17
  * sheetmetal 0.2.57
  * workfeature
Re: Suggestion: Ask for confirmation before overwriting case files
on the other hand if you edited something and you want to write your changes it would be pretty annoying if you had to confirm every time that you want to overwrite.
KAKM
Post by KAKM »
Yeah, I agree that it would be a pain in the rear to get that warning every time when you were getting a case set up/tweaked. What might make more sense is a popup (that has a "do not show again" option) that says something like "back up this result?" after a case successfully runs. It would save the results with an appropriate new file/directory name, and then your "working case" would proceed as normal. Or just having "back up results" as a box that could be checked in the preferences menu.
