Budahn wrote: ↑Tue Sep 06, 2022 9:57 pm
Its weird because when you run the same simulations in RANS everything goes right, i think the problem is with LES and DES turbulence models.
Yes, RANS/k-omega turbulence seems a better approach.
I have no experience with buoyantPimpleFoam/LES, but as far as I understand LES,
you need a much finer mesh to resolve the eddies.
See
https://www.youtube.com/watch?v=r5vP45_6fB4 as a start.
I wonder why you use buoyantPimpleFoam for your simulation. The effect of buoyancy is nearly zero.
Why is your g-vector pointing in -y direction?
My sim is done with a 2D-approach. If you are interested in simulating some basic phenomena,
you should start with 2D. Sim runs much faster, you can play with the mesh and the boundaries and s.o.
in a much shorter time. Disadvantage: 2D is not appropriate for LES, according to
https://www.openfoam.com/documentation/ ... e-les.html
However, have a nice weekend.
Regards Thomas
Meshing needs 1 min, running full 30 sec sim needs approx 20 min.
- cooler.JPG (64.06 KiB) Viewed 1155 times
