CfdOF can not start ParaView
Moderator: oliveroxtoby
ReneSci
Post by ReneSci »
Just installed the latest FreeCad 0.20.1 and updated CfdOF, ParaView etc.
Now it seems like CfdOF can not start ParaVew from within the CfdOF gui.
I get this messages;
01:06:16 Traceback (most recent call last):
01:06:16 File "C:\Users\xxxx\AppData\Roaming\FreeCAD\Mod\CfdOF\.\CfdOF\Solve\TaskPanelCfdSolverControl.py", line 302, in openParaview
01:06:16 self.open_paraview = CfdTools.startParaview(case_path, script_name, self.consoleMessage)
01:06:16 File "C:\Users\xxxx\AppData\Roaming\FreeCAD\Mod\CfdOF\.\CfdOF\CfdTools.py", line 1227, in startParaview
01:06:16 CfdConsoleProcess.removeAppimageEnvironment(env)
01:06:16 AttributeError: type object 'CfdConsoleProcess' has no attribute 'removeAppimageEnvironment'
In the Preferences/CfdOF/ParaView executable path, I have put
C:/Program Files/ParaView 5.10.1-Windows-Python3.9-msvc2017-AMD64/bin/paraview.exe
The other directory fields are left empty.
Does this make any sense to you ?
Version: 0.20.1.29410 (Git)
Branch: releases/FreeCAD-0-20
Locale: Danish/Denmark (da_DK)
  * A2plus 0.4.56a
  * ArchTextures
  * Assembly4 0.12.3
  * CfdOF 1.17.8
  * Defeaturing
  * Dracula 0.0.2
  * ExtremeProDark 1.0.4
  * IconThemes
  * lattice2 1.0.0
  * Manipulator 1.4.9
  * MeshRemodel 1.8919.0
  * parts_library
  * Plot 2022.4.17
  * sheetmetal 0.2.56
  * workfeature
ReneSci
Re: CfdOF can not start ParaView
Post by ReneSci »
Is there a way to start ParaView manually and read a simulation result ?
thschrader
Post by thschrader »
ReneSci wrote: Sat Sep 03, 2022 5:29 am Is there a way to start ParaView manually and read a simulation result ?
After running the case, doubleclick on the pv.foam file, paraview opens, select decomposed case.
You can do the same with the meshcase.
oliveroxtoby
Post by oliveroxtoby »
ReneSci wrote: Fri Sep 02, 2022 11:15 pm 01:06:16 CfdConsoleProcess.removeAppimageEnvironment(env)
My mistake. It should be working now - please update your workbench.
ReneSci
Post by ReneSci »
Yes, it works again.
Thank you.
Also - thank you for the info on starting ParaView manually. Could be useful sometimes.
