Refuse to store unregistered object: grad(U)
Moderator: oliveroxtoby
Budahn
Post by Budahn »
I´m having this problem trying to start a simulation with LES, KEqn turbulence model, can anyone run this without problem?
18:58:26  [1]
[5]
[2]
[3]
[4] [0]
[1]
[5]
[2]
[3]
[4]
[0]
[1]
[5]
[2]
[3]
[4]
[0]
--> FOAM FATAL ERROR:
(openfoam-
(openfoam-
(openfoam-
(openfoam-
(openfoam-
(openfoam-
2012
2012
2012
2012
2012
2012
18:58:26  )
[1]
[2]
[3]
[5]
[4]
[0]
Failed to store pointer: grad(U). Risk of memory leakage
[1]
[2]
[3]
[5]
[4]
[0]
[1]
[2]
[3]
[5]
[4]
[0]
[1]
[2]
[3]
[5]
[4]
[0]
    From
    From
    From
    From
    From
    From
static Type& Foam::regIOobject::store(Type*) [with Type = Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>]
[1]
[2]
[3]
[5]
[4]
[0]
    in file
    in file
    in file
    in file
    in file
    in file
/home/buzz2/pawan/openfoam/main/2012/src/OpenFOAM/lnInclude/regIOobjectI.H
 at line
 at line
 at line
 at line
 at line
 at line
67
67
67
67
67
67
[1]
[3]
[5]
[4]
[2]
[0]
FOAM parallel run aborting
[1]
[3]
[5]
[4]
[2]
[0]
18:58:26
job aborted:
[ranks] message
[0] application aborted
SimulationForum.FCStd
(46.01 KiB) Downloaded 29 times
oliveroxtoby
Re: Refuse to store unregistered object: grad(U)
Post by oliveroxtoby »
Budahn wrote: Mon Jul 18, 2022 10:05 pm I´m having this problem trying to start a simulation with LES, KEqn turbulence model, can anyone run this without problem?
Should be working now.
