Python support in paraview not found. (solved)
Moderator: oliveroxtoby
fungnow
Post by fungnow »
installed 0.19 0.20 0.21
upon "Run dependency checker" I get this:
Paraview executable: C:\Users\fungnow\Pulsejets\ParaView 5.5.2-Qt5-Windows-64bit\bin
Python support in paraview not found. Please install paraview python packages.
at this point I dont know what to do!!!!!
david69
Re: Python support in paraview not found.
Post by david69 »
you read the red rubbon top of the forum and apply it with detailed info. thanks.
fungnow
Post by fungnow »
Sorry found my problem
thank u for fast reply thou!
@fungnow please modify the title of the 1st post to [SOLVED]
tone_alone
Re: Python support in paraview not found. (solved)
Post by tone_alone »
Hi all, not sure if I should've started a new thread but I'm having a similar issue with ParaView and don't know how to resolve
here's my Freecad info:
OS: macOS 10.16
Version: 0.21.30193 (Git)
Hash: a8cb4e744483ce2c4b0770b948105a766330a4b2
Python 3.10.6, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.2
Locale: C/Default (C)
  * freecad-mbdyn-dynamics-workbench-master
  * Behave-Dark-Colors 0.1.1
  * InventorLoader 1.3.0
  * EM
  * Render 2022.2.0
  * CfdOF 1.17.7
  * OSE3dPrinter
  * SelectorToolbar
  * A2plus 0.4.56a
  * lattice2 1.0.0
  * sheetmetal 0.2.56
  * CubeMenu
  * Curves 0.5.6
This is the output when I check dependancies for CfdOF:
Checking dependencies...
System: Darwin
Runtime: Posix
OpenFOAM directory: /Volumes/OpenFOAM-v2206
HiSA not found
Paraview executable: /Applications/ParaView-5.10.1.app/Contents/bin/pvpython
gmsh executable: /usr/local/Cellar/gmsh/4.10.5_1/bin/gmsh
I'm running OpenFOAM for MacOS provided here:
https://github.com/gerlero/openfoam-app
CfdOF seems to run within FreeCAD; I was able to complete this tutorial up to the point of viewing the sim in ParaView:
https://www.youtube.com/watch?v=OS4sbbBtZUw&t=958s
@fungnow-can you share how you fixed this issue?
Thanks
oliveroxtoby
Post by oliveroxtoby »
tone_alone wrote: Fri Aug 26, 2022 9:04 pm Hi all, not sure if I should've started a new thread but I'm having a similar issue with ParaView and don't know how to resolve
OS: macOS 10.16
I don't know how it is in macOS, but in some Linux distributions, the python scripting functionality in paraview is provided by a separate package, called something like 'python3-paraview' (that's what it is on Ubuntu 20.04). If it's installed correctly, the command 'pvpython' should be available.
KAKM
Post by KAKM »
oliveroxtoby wrote: Sun Sep 04, 2022 3:32 pm I don't know how it is in macOS, but in some Linux distributions, the python scripting functionality in paraview is provided by a separate package, called something like 'python3-paraview' (that's what it is on Ubuntu 20.04). If it's installed correctly, the command 'pvpython' should be available.
I installed ParaView using Homebrew and didn't have any problems, so if that's how they did it, it should be fine. The line that caught my attention was
On my install, that point in the directory is an executable-which means pvpython is there. I think the problem may be that CfdOf is looking inside .../pvpython for the file pvpython.
@tone_alone, I think you may have put the wrong path into the CfdOf preference panel. This is what mine looks like, and it works.
Screen Shot 2022-09-12 at 10.56.24 AM.png (39.26 KiB) Viewed 1933 times
tone_alone
@KAKM, thanks for posting the screenshot I also installed Paraview using Homebrew - when I set the executable path to:
but I got the same error, I then tried:
which seemed to solve the problem; I didn't get an error, but(!) Paraview doesn't start when I try to view the mesh, or sim…
