unit of U in paraviewer?
Moderator: oliveroxtoby
tjboon
Post by tjboon »
Hi guys, I get crazy high values in my simulation to the power of 14 while the outlet speed set is only 5m/s? so my question is if im doing anything wrong or whats the unit of U
thschrader
Re: unit of U in paraviewer?
Post by thschrader »
openFOAM uses SI units.
See U/p files after case writing.
EDIT:
the results shown in paraview correspond to openFOAM.
https://www.cfdsupport.com/openfoam-tra ... ode51.html
https://doc.cfd.direct/openfoam/user-gu ... ile-format
tjboon
Post by tjboon »
thschrader wrote: Wed Jul 06, 2022 4:28 pm openFOAM uses SI units.
EDIT:
So the U in paraviewer is actually dynamic viscosity and not velocity?
r.tec
Post by r.tec »
No, U ist velocity with the dimension [m/s]
tjboon
Post by tjboon »
r.tec wrote: Wed Jul 13, 2022 8:57 am No, U ist velocity with the dimension [m/s]
Is there anyway how I can see that in my model? What actually is the velocity in m/s?
r.tec
Post by r.tec »
Yes, in Paraview you can chose "U", then the approriate colour corresponds to velocity U. And as Thomas wrote OpenFOAM takes SI-units, in this case [meter per second or m/s]. Or you can filter for Glyph in Paraview to show the velocity-vectors. But you must play a bit around to find the best relation of Glyph-size to velocity.
r.tec
Post by r.tec »
Example 2D CFD:
2022-02-07 Animated.gif (902.62 KiB) Viewed 2480 times
This animated .gif shows what I mean. The fine lines are streamlines, the colour shows the velocity, or more precise the changes of velocity.
But I do not know what the flash-like artefacts are and where they come from. Not nice but no influence on the results.
trijonb
Post by trijonb »
r.tec wrote: Wed Jul 13, 2022 4:15 pm But I do not know what the flash-like artefacts are and where they come from. Not nice but no influence on the results.
These look like processor patches (ie results processed on a decomposed mesh). Looks like you may have used np=4?
KAKM
Post by KAKM »
tjboon wrote: Wed Jul 06, 2022 10:49 am I get crazy high values in my simulation to the power of 14 while the outlet speed set is only 5m/s
Even if your simulation had somehow gotten set to nm/s (unlikely), you would still only be seeing 10^9 or so. Sounds like your simulation diverged/blew up. Did you use a velocity inlet? You can get weird results if there's nothing to bound the pressure. Or you might have used too large of a timestep, or had bad mesh elements somewhere. It's hard to say without more information on your simulation.
