2D meshing
Moderator: oliveroxtoby
oliveroxtoby
2D meshing
Post by oliveroxtoby »
In version 1.11.1 there has been a change to the method of creating a 2D mesh in CfdOF.
At present, CfdOF doesn't support any native 2D meshers. Instead, the way to generate a 2D mesh is to generate a 3D mesh and then extrude a single layer of cells from one of its faces. Previously this was accomplished by specifying front and back faces as special "2D bounding plane" boundary conditions, with the extrusion operation being handled in the background by CfdOF. However, this approach did not extend well to the case of generating a 'wedge' mesh for an axisymmetric analysis.
The 2D mesh extrusion is now handled explicitly as an extrusion operation defined as a mesh refinement region (CfdOF | Mesh refinement | Extrusion). This allows for the creation of both planar 2D meshes and 2D wedge meshes, but also more general extrusions such as generating 3D sectors and extrusions that extend exising meshes with layers of cells at boundary patches.
Please provide all the information requested in this post before reporting problems with CfdOF.
thschrader
Re: 2D meshing
Post by thschrader »
2D-meshing now:
Create additional MeshRefinement-object in model-tree, open dialog,
select Extrusion, Extrusion type=2D planar, set thickness.
Select Face, add. Run mesher, selected face is extruded to a 2D-mesh,
2 more patch entries in createPatchDict.
Example-file:
naca2412.FCStd
(384.53 KiB) Downloaded 199 times
How to use these guys?
Done with
Version: 0.20.27428 (Git)
Hash: 27460358508a2057e0ec57a418641435f12628dd
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
thschrader
Re: 2D meshing
2D-wedge-mesh axisymmetric.
blue_origin_capsule.FCStd
(845.44 KiB) Downloaded 152 times
thschrader
Re: 2D meshing
Just updated
cfdof-wb
hisa 1.6.1
cfmesh-cfdof (1.1.2) 1.12
2D planar meshing works with naca example from above
2D wedge meshing gives back error with capsule example from above, see log
2D patch normal/rotational meshing: not tested
--> FOAM FATAL IO ERROR:
keyword axisPt is undefined in dictionary "C:/GA-NT/Anwendungen/TS_513538/CFD/meshCase/system/extrudeMeshDict/sectorCoeffs"
file: C:/GA-NT/Anwendungen/TS_513538/CFD/meshCase/system/extrudeMeshDict/sectorCoeffs from line 28 to line 30.
    From function const Foam::entry& Foam::dictionary::lookupEntry(const Foam::word&, bool, bool) const
    in file db/dictionary/dictionary.C at line 799.
FOAM exiting
Done with bluecfd and
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
oliveroxtoby
Re: 2D meshing
thschrader wrote: Sun Mar 20, 2022 10:00 am
FOAM exiting
Sorry - this was caused by an OpenCFD vs Foundation divergence. Should be working now.
Re: 2D meshing
to simulate a 2d case, what boundary conditions do I need to set for the faces parallel to the 2D plane?
oliveroxtoby
Re: 2D meshing
adrianinsaval wrote: Sat May 21, 2022 9:48 pm to simulate a 2d case, what boundary conditions do I need to set for the faces parallel to the 2D plane?
No boundary condition should be specified - these will be set automatically.
CFD-ROC
Re: 2D meshing
Post by CFD-ROC »
I'm new to CfdOF and OpenFOAM. I worked through the demo files and it helped me a lot to understand the workflow. It is really a great WB for FreeCAD!
I was able to run all of the demo files successfully but may I ask if someone can provide a very simple demo of a 2D rotational case ? In the demo files only 2D planar is covered. I'm using the latest FreeCAD 0.20 (see below) and CfdOF 1.17.
Thanks!
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
oliveroxtoby
Re: 2D meshing
CFD-ROC wrote: Sun Jul 10, 2022 8:02 am Hello,
Thanks a lot.
How about this message, above in the current thread?
thschrader
Re: 2D meshing
Here is an example, rotational mesh at 45 deg.
Meshing works, but sim does not run.
Maybe I do something wrong with the boundaries.
curved_wing.FCStd
(249.74 KiB) Downloaded 82 times
Cannot find patchField entry for patch_0_1_back
file: C:/GA-NT/Anwendungen/TS_513538/CFD/case/0/p/boundaryField from line 25 to line 47.
    From function void Foam::GeometricField<Type, PatchField, GeoMesh>::Boundary::readField(const Foam::DimensionedField<TypeR, GeoMesh>&, const Foam::dictionary&) [with Type = double; PatchField = Foam::fvPatchField; GeoMesh = Foam::volMesh]
11:28:07      in file X:/OpenFOAM-8/src/OpenFOAM/fields/GeometricFields/GeometricField/GeometricBoundaryField.C at line 184.
FOAM exiting
Done with
bluecfd, cfMesh-CfdOF (cfMesh 1.1.2) 1.17
Version: 0.21.29485 (Git)
Hash: a236ca843fdd6674afb6d7ed1454fbd3b547f5ea
  * BIM
  * CfdOF 1.17.0
  * Curves 0.3.0
  * Defeaturing_WB
  * dodo
  * Fasteners
  * FEM_FrontISTR 0.1.0
  * Manipulator 1.4.3
  * Plot
  * Reinforcement
  * WorkFeature
