Combustion
Moderator: oliveroxtoby
thschrader
Re: Combustion
Post by thschrader »
Dimensions of the body?
fungnow
Re: Combustion
Post by fungnow »
the setup and geometry is in the case above!
RamjetCombustion.FCStd
(18.36 KiB) Downloaded 63 times
trying to sim this jet http://www.luft46.com/misc/skp14.html
fungnow
Re: Combustion
Post by fungnow »
Epiphony: Combustion is a bunch of snakes! Who Knew!?
Using "ReactingFoamTutorial" -> https://www.cfd.at/sites/default/files/ ... Eleven.pdf
and "CFD Tutorial 1 - Elbow" from CSIR as guides!
https://raw.githubusercontent.com/opens ... 0Elbow.pdf
and C:\Users\~~~\FreeCAD 0.19\v2012\msys64\home\ofuser\OpenFOAM\OpenFOAM-v2012\tutorials\combustion\reactingFoam\laminar\counterFlowFlame2D
the ignition is accomplished by an input of mixture of N2 and methane superheated to temp of association (800 K)
back to 3D model using OpenFOAM sheets from above example
https://www.cemf.ir/PDFs/OpenFOAM/Sandi ... ngFoam.pdf
the outer ring enters air 294 K
the middle superheated mix at 1880 K (spark plug)
the inner ring methane 294 K.
However ignition by method from Tutorial above!
is there methane in freeCAD???
so now after meshing and writing case
select "edit" option and hack!
fungnow
Re: Combustion
Post by fungnow »
[video]C:\Users\fungnow(avisom.avi)[/video]
wanted to post short video but cannot find how to do it?????
Re: Combustion
fungnow wrote: Mon Jan 10, 2022 8:29 pm [video]C:\Users\fungnow(avisom.avi)[/video]
upload to youtube or some other hosting service then paste the link here and try using the [video] tag, I'm not sure what sites are supported but I think at least youtube is supported. Maximum file size for attachments in the forum is 1.5mb so you won't be able to post a video here directly, if it's short and audio and image quality are not important you can try converting to a gif that has less than 1.5mb and upload that as an attachment
Re: Combustion
The Upload Limit is 1MB.
fungnow
Re: Combustion
Post by fungnow »
Thank you much! Youtube it is, in a while!
fungnow
Re: Combustion
Post by fungnow »
phpBB [video]
Reason: used video tags for clip
fungnow
Re: Combustion
Post by fungnow »
test of pulse fuel inlet , the code was on UTb title "Pulsing Inlet Velocity"
testing editing CASE before solving
                     ????       use "Analysis control" "Edit" Case button!
          THIS WILL IMPLEMENT "Pulsing Inlet Velocity" (find it on UTb)
inletGas
        // Fix all three components of velocity on inflow and only the normal component on outflow,
        // in order to be well-posed if there are some faces on the patch which are actually outflows.
        type                fixedNormalInletOutletVelocity;
        fixTangentialInflow yes;
        normalVelocity
            type            uniformFixedValue;
            value           uniform ( 3.2 0.0 0.0 );
            uniformValue sine;
            uniformValueCoeffs
              frequency 2;
              amplitude 5;
              level (10 0 0);
              scale (1 0 0);
Reason: added code tags
