OS: Windows 10 Version 1909
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
I tried to run the simulation but it exited with error. There is no error message in the message window (messages below):
09:49:22 Writing case to folder C:\Users\Admin\AppData\Local\Temp
09:49:22 Matching boundary conditions ...
09:49:23 Populating createPatchDict to update BC names
09:49:23 Successfully wrote case to folder C:\Users\Admin\AppData\Local\Temp
09:49:27 Solver run command: C:\PROGRA~1\BLUECF~1\msys64\usr\bin\bash --login -O expand_aliases -c cd "/c/Users/Admin/AppData/Local/Temp/case" && ./Allrun
09:49:27 C:\PROGRA~1\BLUECF~1\msys64\usr\bin\bash --login -O expand_aliases -c cd "/c/Users/Admin/AppData/Local/Temp/case" && ./Allrun
09:49:27 Raw command: ['C:/Program Files/FreeCAD 0.19/bin\\python.exe', '-u', 'C:\\Users\\Admin\\AppData\\Roaming\\FreeCAD\\Mod\\CfdOF\\WindowsRunWrapper.py', 'C:\\PROGRA~1\\BLUECF~1\\msys64\\usr\\bin\\bash', '--login', '-O', 'expand_aliases', '-c', 'cd "/c/Users/Admin/AppData/Local/Temp/case" && ./Allrun']
09:49:30 Setting environment for OpenFOAM 5.x mingw-w64 Double Precision (of5-64), using MSMPI71 - please wait...
09:49:30 Environment is now ready. Notes:
- You can change between installed versions by running: ofmenu
- You can change to other predefined versions by running: ofmenuNew
09:49:34
The subject of the simulation is to simulate the flow of air in front of exhaust slots. I have attached the model. Advice is appreciated.
Thx Marcus
Troubles with simulation
Moderator: oliveroxtoby
- Air exhaust_MEGA.FCStd
- (69.79 KiB) Downloaded 78 times
- oliveroxtoby
Re: Troubles with simulation
It runs on my system. Please try upgrading to the latest version of BlueCFD, or alternatively the ESI installation of OpenFOAM. We did have a problem that looks like this that was caused by a conflict between BlueCFD dlls and those provided by FreeCAD. A workaround has been implemented, but I don't know if it works with the old version. Obviously also please make sure your workbench is up to date.Sidemountyucatan wrote: ↑Tue Oct 05, 2021 7:42 am OS: Windows 10 Version 1909
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
09:49:34
Thx Marcus
Thx for your feedback. I did how you suggested. Newest BlueCFD Core -> direct path in the settings / Paraview path reset / new cfmesh / new HISA etc. etc.. But nevertheless I got the following error message (no changes to the model):
Errormessage in the task window:
0.0: Checking dependencies...
0.0: Case writer called
0.1: Matching boundary conditions ...
0.3: Case written successfully
0.0: Solver started
323.7: OpenFOAM IO error: Cannot find patchField entry for face0 file: C:/Users/marcu/Desktop/CFD_data files/case/0/U/boundaryField from line 27 to line 19.
324.2: Simulation exited with error
Errormessage in the message window:
13:04:02
--> FOAM FATAL IO ERROR:
From function void Foam::GeometricField<Type, PatchField, GeoMesh>::Boundary::readField(const Foam::DimensionedField<TypeR, GeoMesh>&, const Foam::dictionary&) [with Type = Foam::Vector<double>; PatchField = Foam::fvPatchField; GeoMesh = Foam::volMesh]
in file X:/OpenFOAM-8/src/OpenFOAM/fields/GeometricFields/GeometricField/GeometricBoundaryField.C at line 184.
FOAM exiting
Do I interpret correctly that the solver has problems by identifying face0 ?
Thx for your help.
0.0: Solver started
13:04:02
FOAM exiting
Thx for your help.
- oliveroxtoby
This can happen if changes are made to the model between generating the mesh and running the solver. Please re-do all steps from scratch to check the reproducibility of the problem from the saved state that you provided: Write mesh; Run mesher; Write case; Run solver. It runs fine for me.Sidemountyucatan wrote: ↑Mon Oct 11, 2021 12:25 pm Thx for your feedback. I did how you suggested. Newest BlueCFD Core -> direct path in the settings / Paraview path reset / new cfmesh / new HISA etc. etc.. But nevertheless I got the following error message (no changes to the model):
0.0: Solver started
13:04:02
FOAM exiting
Thx for your help.
