Hi Oliver,
i saw you made a cfMesh update today morning.
Updateing my system installation of OpenFoam to 2106 and try to install cfMeshfinised with the same error 2 as before..
The install process seams to stop a bit later, i think , because the Allwemake logfile contends a few lines more.
If i try to install Hisa to that incomplete cfMesh installation it works and if i run the dependency checker it's missing cfMesh only. Trying install cfMesh after Hisa also fails.
Btw.: i'm gone back to Leap 15.3, because at the OpenFoam wiki is a hint that a working installation at Tumbleweed is mostly not possible. Here the system i an now:
OS: openSUSE Leap 15.3 (KDE//usr/share/xsessions/plasma5)
Version: 0.20.25220 (Git) AppImage
Hash: 46282db7c8c65d1205a4cd03499d4beadb1573c6
Python version: 3.9.6
Qt version: 5.12.9
OCC version: 7.5.2
Attached the last files for the output (FC and Allwmake)
Do you have any idea ?
[SOLVED) ]cfMesh : Install finished with error 2
Moderator: oliveroxtoby
Re: cfMesh : Install finished with error 2
- cfMesh_install_output_2106.txt
- (265 Bytes) Downloaded 82 times
- log.Allwmake_2106_new.txt
- (435.85 KiB) Downloaded 71 times
- FC_Python_console_output.txt
- (679 Bytes) Downloaded 68 times
- FC_output_2106_2106_new.txt
- (429.98 KiB) Downloaded 82 times
Gruß Herbert
- oliveroxtoby
The first error indicates zlib.h is not found. You need to install the package that provides it - probably zlib-devel or something like that.herbk wrote: ↑Wed Jul 14, 2021 11:22 am Hi Oliver,
Hi Oliver,
I have had a lzlib-devel instead, - is that zlib.h needed by OpenFoam or by cfMesh?
I read at OpenFoam Wiki about it, but have installed OpenFoam from the OpenSuse (science) Repo with package manager, it should solve the dependencys...
thank you, that solved the install problem of cf Mesh !oliveroxtoby wrote: ↑Wed Jul 14, 2021 12:42 pm The first error indicates zlib.h is not found. You need to install the package that provides it - probably zlib-devel or something like that.
Gruß Herbert
