cfdOF install not detecting OpenFOAM install
Moderator: oliveroxtoby
justJETZ
Re: cfdOF install not detecting OpenFOAM install
Post by justJETZ »
Hi attached with this reply should be the SIphon_v2.FCStd.
I created the geometry in FreeCAD using Sketcher, then padded it 10mm and opened the cfdOF workBench.
Create a new CFD Analysis, first set the PhysicsModel, then FluidProperties to water.
Next, I InitialiseFields setting pressure and velocity both to potential flow.
Then I proceed to mesh the geometry using cfMesh with an element size of 2mm (I keep getting a "Links go out of the allowed scope" error/warning over here)
Now I set the boundary conditions
Face7 and Face15 are both inlets with Uy = 1 mm/s
Face22: outlet
Face23 and Face24 are the front and back walls set to slip(inviscid)
The rest of the faces are wall with noSlip
I then run the solver and receive the output as shown in the code section in the previous reply on this thread.
Hope that is everything needed.
Siphon_v2.FCStd
(29.14 KiB) Downloaded 114 times
oliveroxtoby
Post by oliveroxtoby »
justJETZ wrote: Mon Jun 21, 2021 10:00 am Hi attached with this reply should be the SIphon_v2.FCStd.
Face22: outlet
Unfortunately I can't reproduce this error. I open your case, Write Mesh, Run Mesher, Write case, Run case, and everything runs fine. The simulation eventually diverges but this is recitifed by changing the sign of the inlet velocity so that it points inwards. Please verify you have the latest updated workbench and double-check the process from scratch when loading from your file.
justJETZ
Post by justJETZ »
Started up Ubuntu today and randomly just tried running the simulation in the saved state I sent to you. Strangely, it ran :lol: .
The gremlins of software are beyond me. Anyway after 36 seconds into the simulation, it crashes for me as well. I then changed the sign for the inlet velocity as you mentioned and it converged after 743 iterations.
When running ParaView however, ParaView does not want to detect the residuals after loading the pv.foam file.
I then selected the Decomposed case and the residuals show up.
Any reason as to why the residuals would not be detected by Paraview in the Reconstructed case?
A quick fix would be to not run the simulation in parallel I guess.
oliveroxtoby
justJETZ wrote: Mon Jun 28, 2021 8:44 am
Selecting 'Decomposed case' instructs paraview to read the parallel case; 'Reconstructed case' reads the serial case. So if the case was run in parallel, you won't see serial results unless you explicitly reconstruct them using OpenFOAM. Simpler just to work with the parallel version directly. This will be automatically selected if you use the 'Paraview' button in CfdOF.
justJETZ
Post by justJETZ »
Fair enough I will just go with the parallel case.
Thank you for all the help, I greatly appreciate it.
rssg
Post by rssg »
justJETZ wrote: Sun Jun 20, 2021 12:03 pm Ok
FreeCAD is detecting both OpenFOAM installations, and I have successfully installed cfMesh and HiSA. Running the dependency checker yields no errors.
Not sure if I can ask this here or if I should open another thread.
When clicking "Run" for the solver I get the following output in the Report view.
13:57:24  Solver run command: bash -c cd "/tmp/case" && ./Allrun
13:57:24  bash -c cd "/tmp/case" && ./Allrun
13:57:24  Raw command:  ['bash', '-c', 'cd "/tmp/case" && ./Allrun']
13:57:24  /*---------------------------------------------------------------------------*\
| \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox           |
|  \\    /   O peration     | Version:  2012                                  |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
|    \\/     M anipulation  |                                                 |
Build  : _e91649cfd8-20210420 OPENFOAM=2012 patch=210414
Arch   : "LSB;label=32;scalar=64"
Exec   : createPatch -overwrite
Date   : Jun 20 2021
Time   : 13:57:24
Host   : jitish-linux
PID    : 32400
13:57:24  I/O    : uncollated
Case   : /tmp/case
nProcs : 1
trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE).
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create polyMesh for time = 0
13:57:24  Reading "system/createPatchDict"
Adding new patch inlet1 as patch 1 from
    type            patch;
Adding new patch inlet2 as patch 2 from
    type            patch;
Adding new patch outlet as patch 3 from
    type            patch;
Adding new patch pipeWalls as patch 4 from
    type            wall;
Adding new patch slipWalls as patch 5 from
    type            wall;
Adding new patch defaultFaces as patch 6 from
    type            patch;
--> FOAM Warning :
    From Foam::labelHashSet Foam::polyBoundaryMesh::patchSet(const Foam::UList<Foam::wordRe>&, bool, bool) const
    in file meshes/polyMesh/polyBoundaryMesh/polyBoundaryMesh.C at line 896
    Cannot find any patch or group names matching "patch_1_.*"
--> FOAM Warning :
    Cannot find any patch or group names matching "patch_2_.*"
--> FOAM Warning :
    Cannot find any patch or group names matching "patch_3_.*"
--> FOAM Warning :
    Cannot find any patch or group names matching "patch_4_.*"
--> FOAM Warning :
    Cannot find any patch or group names matching "patch_5_.*"
Moving faces from patch patch_0_0 to patch 6
Doing topology modification to order faces.
Not synchronising points.
Removing patches with no faces in them.
Removing zero-sized patch patch_0_0 type patch at position 0
Removing patches.
Writing repatched mesh to 0
13:57:24  End
Exec   : potentialFoam -initialiseUBCs -pName p -writep
Date   : Jun 20 2021
Time   : 13:57:24
Host   : jitish-linux
PID    : 32407
Case   : /tmp/case
nProcs : 1
Create time
Create mesh for time = 0
13:57:24
potentialFlow: Operating solver in PISO mode
Reading velocity field U
Constructing pressure field p
Constructing velocity potential field Phi
No MRF models present
Calculating potential flow
GAMG:  Solving for Phi, Initial residual = 0, Final residual = 0, No Iterations 0
13:57:24  GAMG:  Solving for Phi, Initial residual = 0, Final residual = 0, No Iterations 0
Continuity error = 0
Interpolated velocity error = 0
Calculating approximate pressure field
13:57:24  #0  Foam::error::printStack(Foam::Ostream&) at ??:?
13:57:24  #1  Foam::sigFpe::sigHandler(int) at ??:?
#2  ? in /lib/x86_64-linux-gnu/libpthread.so.0
13:57:24  #3  ? in /usr/lib/openfoam/openfoam2012/platforms/linux64GccDPInt32Opt/bin/potentialFoam
#4  ? in /usr/lib/openfoam/openfoam2012/platforms/linux64GccDPInt32Opt/bin/potentialFoam
#5  ? in /usr/lib/openfoam/openfoam2012/platforms/linux64GccDPInt32Opt/bin/potentialFoam
#6  __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6
13:57:24  #7  ? in /usr/lib/openfoam/openfoam2012/platforms/linux64GccDPInt32Opt/bin/potentialFoam
13:57:24  ./Allrun: line 4: 32407 Floating point exception(core dumped) "$@" > >(tee -a log."$sol") 2> >(tee -a log."$sol" >&2)
All the text under the "Calculating approximate pressure field" should be in red.
I did notice the 5 FOAM Warnings above as well, but I am not sure how to fix this.
Hello everyone,
justJETZ, i have the same problem but i can't solve it yet, exactly, how do you solve the openfoam path install recognition?
Best.,
Ricardo
techGuy
Post by techGuy »
This is either a meshing error or you don't have the inlet, outlet, walls and surface patches set up properly.
I suggest posting your FCStd file here so we can open it and see what is going on with your model.
rssg
Post by rssg »
I solved the opeanfoam installation path, using FreeCAD 0.19 version, and openfoam 2206 from openfoam.com.
Im trying to execute my first simulation but in the mesh step, when i Run mesher, i get the next error:
08:08:07 Executing: ./Allmesh in /tmp/meshCase
08:08:07 /usr/lib/openfoam/openfoam2206/bin/foamEtcFile: 134: dirname: not found
08:08:07 Could not determine OPENFOAM 'api' value
/usr/lib/openfoam/openfoam2206/bin/foamCleanPath: 279: sed: not found
08:08:07 ./Allmesh: línea 20: basename: orden no encontrada
./Allmesh: línea 23: tee: orden no encontrada
Maybe someone could help me?
Best.
rssg
Post by rssg »
When i run the dependency checker i get this result:
Checking dependencies...
System: Linux
Runtime: Posix
OpenFOAM directory: /usr/lib/openfoam/openfoam2206
OpenFOAM installation does not include 'wmake'. Installation of cfMesh and HiSA will not be possible.
MPI is not installed. Parallel execution will not be possible.
cfMesh (CfdOF version) not found
HiSA not found
Paraview executable: /home/cierhi/Paraview/bin/paraview
gmsh executable: /home/cierhi/gmsh/gmsh
Completed CFD dependency check
I don't know why the plugin can't read 'wmake' folder if its there in OpenFOAM directory.
Best.
herbk
Post by herbk »
rssg wrote: Thu Apr 06, 2023 1:13 pm Maybe someone could help me?
may be this can help:
viewtopic.php?p=667277#p667277
and, btw, switch to a up to date FC, - 0.19 is outdated...
Gruß Herbert
