You are quite right, that is an error. Thanks for pointing it out. (The formula used in CfdOF, however, is the correct one.)hllbls wrote: ↑Fri Jul 02, 2021 1:07 pm Hello Mr. Oliver i just realized something: The formula you used in tutorial cases about 'k' seems to be wrong. You defined as "3/2*I*U^2" instead of "3/2*(I*U)^2" . I have to pay attention to initial conditions because my meshs are fully made of tet meshs, so it is so sensitive to init conditions.
Could you explain why did you use this formula or is there any mistake ?
Have good days!
Hisa Solver /Tutorial is not running
Moderator: oliveroxtoby
- oliveroxtoby
